Hello!
My friends, I need some help - can you recommend a solution to coat the rear-top seal of a Saab rear window? The seal integrity is fine, but there is a black painted strip of metal above it, where the black paint has worn off, over the years. I had suggested self-amalgamating tape (as used for weatherproof seals for sat dishes - we used to use that a lot) but I wasn't sure if this would be correct advice.
If you know, would you reply? Many thanks me old Chinas.
