I wonder how much power it would be for my integrales 30psi!
It would be interesting to see how ambient temperature throws the results. Say from -20 to +60 (under bonnet).
To do that we need an estimate of the air flow. I'm looking for a number for the fuel efficiency of a typical engine. One number I found was 240 g of petrol per kWh of output, but I'm looking for more data for verification. Apparently engine dynamometer charts give this info. Any petrolheads got an example? Once we have this we just have to go with the power output of the engine and we can figure the fuel flow and the air flow from that.Wikipedia says the 1.9 Twinturbo Multijet 16V Integrale develops 190 hp.
See below. High ambient temperatures significantly increase the power requirement on the compressor for the same boost.
Thanks. Not as much increase in pumping energy as I expected but 131 degrees inlet manifold temp is not pretty.
Quote from: Chet T16 on July 26, 2012, 10:06:53 pmI wonder how much power it would be for my integrales 30psi!To do that we need an estimate of the air flow. I'm looking for a number for the fuel efficiency of a typical engine. One number I found was 240 g of petrol per kWh of output, but I'm looking for more data for verification. Apparently engine dynamometer charts give this info. Any petrolheads got an example? Once we have this we just have to go with the power output of the engine and we can figure the fuel flow and the air flow from that.Wikipedia says the 1.9 Twinturbo Multijet 16V Integrale develops 190 hp.
Fuel efficiency is irrelevant. All you need is the engines displacement, the RPM and a fair estimation of the volumetric efficiency.I did mention the TurboZet and the associated Autospeed article:http://autospeed.com/cms/title_The-Twin-Turbo-Zet/A_110827/article.html
Quote from: IanB on July 26, 2012, 11:45:26 pmWikipedia says the 1.9 Twinturbo Multijet 16V Integrale develops 190 hp.This happens to be one of the best documented engines out there.Here are a few bits from Guy Croft's Modifying and Tuning FIAT/Lancia Twin-Cam Engineshttp://www.guy-croft.com/
But isn't that assuming you have a stoichiometric mixture when generally you won't, especially for a turbocharged engine.
FWIW max power on the integrale was at ~5700 rpm and the pressures were measured at the inlet manifold.
It's a petrolhead thread now Congrats on the nice Llancia.
The engine I bolted together for my 1300 kg daily hack does >300hp at the wheels at the same RPM with no forced induction on LPG.And that is with a choking 3.5psi of exhaust back pressure. I really need to ditch the single 3" for a twin 3".
QuoteThe engine I bolted together for my 1300 kg daily hack does >300hp at the wheels at the same RPM with no forced induction on LPG. And that is with a choking 3.5psi of exhaust back pressure. I really need to ditch the single 3" for a twin 3".What car is this?
OK, I confess, not a fair comparison. The stroker kit brought the displacement out to 6.3L.
Quote from: GK on July 27, 2012, 01:27:17 amOK, I confess, not a fair comparison. The stroker kit brought the displacement out to 6.3L.50 bhp/litre? Have you tried running it on something that burns? :p
providing the car is moving the radiator fan will not need to come on.
I think..... in fact this explains why if i open the throttle more the petrol consumption does not massively go up but the car accelerates
Quote from: Simon on July 26, 2012, 05:08:11 pmproviding the car is moving the radiator fan will not need to come on.how can you be sure? what "test distance" we talking about? ps: ferrari is fanless radiator though
