I put some of those into an order on a whim, and of the 3 I got, one went up in flames on test ( I was powering it from a 12V SLA pack just to see if it actually worked) with only a 30ma load from the USB voltage monitor on it, and I decided the other 2 were probably going to have a similar fate, so took one apart to see why. Tiny ceramic capacitors inside, no fuse at all other than the traces, inductor that looked barely capable of 50mA let alone the 1A plus claimed, soldering that was really horrid ( even for the lowest cost shops) and generally shoddy thin board and a tiny 5 pin SMD switcher there.
I recycled an old Nokia charger, and simply grafted a micro USB plug onto the end in place of the Nokia plug, and it works perfectly for charging at 500ma for my needs. 5V 650ma rating, and can actually deliver it as well. Finnish tech at it's best.
