Haha VERY true. The model building side is getting that too. I probably work more with tiny bits on models more than electronics, even a 1/8 watt through hole resistor is bigger than many of my model detail parts. Those glass diodes though... About the only SMD I do are the resistors to put on the axles of my train cars to activate the signal detection - I figure to have a couple hundred cars, with 2 resistors per, so I just bought a part reel of them. When I was making the first batch, if one of those little buggers popped out of my tweezers I gave a cursory glance at the floor and if it stuck out I picked it up, if not, I just used another. Probably vacuumed up half a dozen once I packed up and vacated the place.
