While we are 'talking' leakage, let us not forget the dreaded electrolytic capacitor leakage that has plagued many electronic appliances of recent AND there is the leakage of MEMCAP Memory Capacitors and NiCad/NiMh MEMPAK's
I have repaired many equipments that had suffered total failure for no other reason than a MEMCAP or MEMPAK failure and resultant leakage corrosion. It makes for a simple diagnosis but is a challenge to repair reliably if the corrosion is extensive. The electrolyte can often penetrate teh PCB structure. This can be fatal for a multi layer PCB.
My only advice would be to check inside any used equipment that you buy to see if a MEMCAP or MEMPAK is fitted. If the equipment is over 5 years old, I replace these memory backup devices after checking that calibration data etc is not going to be lost. If such a preventative maintenance procedure does not appeal, then check the MEMCAP and MEMPAK for leakage every 6 months and at teh first sign, fit a new part. Sadly, when you discover the memory of an equipment is no longer being retained, it is often too late and leakage has already occurred.
I personally have not seen leakage from the CR/BR type lithium coin cell type memory backup technology and I prefer this to the other technologies. Rechargeable lithium coin cells are sometimes used but I am not a great fan of them as very careful charging control is needed to avoid leakage or explosion. One wheeze for you e*ay buyers..... there are many types of equipment that lock up or will not switch on once the memory back-up battery is discharged. These are often sold a 'spares or repair'. In the case of rechargeable lithium coin cells this is quite common as they do not hold their charge like primary lithium cells. All the equipment often requires is a gentle charge of teh memory backup cell followed by a full reset of the microprocessor to clear out the garbage in teh volatile memory . A very cheap repair
I attach a picture of a MEMCAP fitted to a DENON Audio CD recorder. The electrolyte disolved a diodes steel legs, corroded links and associated solder joints and finally travelled along the underside of the PCB, under the laquer, eating any thin copper track that got in its way !. Quite a protracted repair job.
