Thanks for all the help people, I managed to find locally one remote ( white one) that it is 100% compatible,
and got it for 12 EUR .
Identical of the KONIG model ( black one).
I did a good progress with the TV set, I checked and replaced the bad electrolytic capacitors,
in every PCB of it.
And I did managed to fix a problem that I had with the stereo channels, as in stereo mode,
the one speaker was stop working ( the right one).
The screen is in perfect condition, only 15% lost of sharpness , but I have other problems with it.
1) I am having a problem with the Horizontal circuitry I can not set the horizontal size on the screen in the screen limits,
is a bit more wider than it should.
I got a tip that I have to use an smaller capacitor, in the circuitry that it drives the horizontal ,
but I do not know who is the one.
Or at list what is the capacity that the original haves, so to spot it.
2) The next problem that I am facing, is an issue with the pulse who activates the PSU from the stand By mode.
for some reason this pulse gets weak, and have problems to start up the TV.
If it did start up , it can work for hours or just minutes, the specific pulse looks to have issues,
and I think that it haves to do with an polyester capacitor or something that haves issues.
I did do lots of soldering looking for cold solder, but it did not work out.
3) Last night , it started having issues with the vertical hold, and after few minutes of operation the screes starts rolling.
As soon it becomes warm, the rolling keeps happening.
And I have not locate yet the pot that controls the vertical.
I have the repair schematic in PDF , but it is in very low resolution, and there is no chance to read anything about the schematic.
I can read only few tips, and the part list, but no the true schematic.
I had add few pictures of the PCB, if some one likes to help me in a way.
