Author Topic: Using PCB as Direct connector for USBC  (Read 540 times)
Offline Regenerate3dTopic starter
« on: May 11, 2023, 11:01:10 pm »
Hi All,
Looking to make a FDTI device as small as possible and with as few components possible.
I've seen a connector on a PCB please see attached image. Can anyone point me in the right direction with a footprint etc. I'm using Kicad to design the PCB.
Many thanks
Re: Using PCB as Direct connector for USBC
« Reply #1 on: May 11, 2023, 11:29:02 pm »
Sorry I forgot to attach image.
Offline jpanhalt
« Reply #2 on: May 12, 2023, 09:33:55 am »
Seems to be here somewhere around p.42: https://www.usb.org/sites/default/files/USB%20Type-C%20Spec%20R2.0%20-%20August%202019.pdf  Or, at least those dimensioned layouts can help you build your own.
Offline tooki
« Reply #3 on: May 12, 2023, 02:59:56 pm »
0.6mm, with 0.5mm on each side for contacts to stick up, total thickness 0.7mm ±0.05mm. 0.8mm PCB is just a tad too thick, and might damage the plugs.
Offline DavidAlfa
« Reply #4 on: May 12, 2023, 09:54:57 pm »
I have a cheap UV lamp that comes with screen protectors, to harden the glue.
PCB is 0.6mm thick. Inserting width is 6.4mm.
