Author Topic: Alu enclosure SD card hole: Need "rubber closing mechanism"  (Read 850 times)
Offline Martin F
Hi all,
In our data logger we have a small hole for inserting an SD card as part of our end plate.
We're looking for low cost rubber closing mechanisms for this - I've seen these on other products, e.g.:
https://www.kvaser.com/whatever-your-data-logging-needs-kvaser-now-has-a-memorator-to-suit/
However, I've been unable to find these anywhere - I guess I lack the right name for searching for it.
Any tips?
Thanks,
Martin
Offline ebastler
Re: Alu enclosure SD card hole: Need "rubber closing mechanism"
« Reply #1 on: June 15, 2018, 10:12:55 am »
I have not come across these as a standard part. Would assume that they are custom made, just like the plastic enclosure of the example product you showed?
Offline amv
« Reply #2 on: June 15, 2018, 10:33:04 am »
Hej Martin F
Hvis du prøver at google "sd card reader rubber protection" dukker der et par stykker op.
Ellers prøv www.modcover.com og søger på "sd card port silicone rubber dust cover" er der i hvertfald en der
håber det kan bruges
Jan
Hi Martin F
If you google "sd card reader rubber protection" a few will come up.
Otherwise try www.modcover.com and search"sd card port silicone rubber dust cover" They have at least one.
Hopes this helps
jan
Offline Marco
« Reply #3 on: June 15, 2018, 12:28:18 pm »
If you don't need long term availability, you could mill a slot and hole for a dust protector from a Sony Xperia. Those are all over ebay.
Offline NiHaoMike
    • Facebook Page
« Reply #4 on: June 15, 2018, 07:12:08 pm »
3D print some out of TPU?
Offline JohnMc
« Reply #5 on: June 16, 2018, 02:05:28 am »
Not sure if something like this might work for you? Had seen USB ports like this figured someone must do SD card.
http://www.polamco.com/micro-sd-and-dual-sim-card-receptacle/
Offline ikrase
« Reply #6 on: June 16, 2018, 03:05:46 am »
Maybe cast some silicone into milled molds?
Offline Richard Crowley
  • KE7GKP
« Reply #7 on: June 16, 2018, 03:37:46 am »
You could mold your own out of Sugaru.
Unbeatable combination of quick, easy, and cheap.
