Author Topic: looking for build-in reserve battery charger schematic  (Read 1398 times)
Offline 001Topic starter
  • Country: aq
« on: September 17, 2018, 02:10:47 pm »
Hi!
It is possible wellknown theme
But not for me
I`m gonna build mains-powered unit with reserve NiMH (4*AA cells, serial wiring)
Any standard circuits?
Thanx!
Offline David Hess
  • DavidH
Re: looking for build-in reserve battery charger schematic
« Reply #1 on: September 18, 2018, 04:49:14 am »
There are lots of circuits but the problem is implementing charge termination with a NiMH battery.  Rechargeable lithium cells are much easier to deal with.
The following users thanked this post: 001
  • Country: aq
« Reply #2 on: September 18, 2018, 04:59:24 am »
Thanx!
Li-Ions like 18650 looks surplus for RESERVE battery in the 20mA unit
Any ideas?
Offline David Hess
  • DavidH
« Reply #3 on: September 18, 2018, 11:56:06 am »
Lithium rechargeable batteries can just rely on constant voltage charging with a current limit so there are lots of simple options.  Any voltage regulator that includes current limiting can work and there are many intended specifically to charge lithium batteries.
If you can live with a single cell or cells in parallel, then charge balancing is not an issue either although charge balancing for two cells in series is easy enough.
Some of the charge controllers also support limiting current from the power source if that is necessary so they can both charge the battery and power the device without exceeding any power adapter's current rating.
  • Country: aq
« Reply #4 on: September 19, 2018, 05:35:35 am »
Charging for a years is not good for LiIon isnt it? It is RESERVE battery it charges everytime
Offline Zero999
  • 0999
« Reply #5 on: September 19, 2018, 01:14:03 pm »
Li-Ion batteries can be float charged indefinitely without any problems. Once the battery's voltage is equal to the open circuit voltage of the charger, no current flows apart from what's necessary to replenish the loss through internal leakage. The problem is the charge current needs to be lowered, if the cell voltage is below a certain level, but that's a non-issue if it doesn't need to be charged quickly: a low charge current can be provided whatever the voltage. A dead cell detection circuit should be included, so it doesn't attempt to charge the battery, if it's fallen below a certain voltage, as it can be dangerous.  The only issue I can see is that Li-Ion batteries store better at 50% charge.
If the battery doesn't need to be charge quickly, there's no need to worry about termination of NiMh batteries, which can safely be trickle charged at low currents. A current of 1/10C is acceptable for 10 to 20 hours and much lower currents, 1/30C to 1/300C, depending on the manufacturer, can be applied indefinitely. A timer controlling a current source all that's needed to switch from trickle to maintenance charge.
https://en.wikipedia.org/wiki/Nickel%E2%80%93metal_hydride_battery#Trickle_charging
« Last Edit: September 19, 2018, 01:17:02 pm by Hero999 »
Offline David Hess
  • DavidH
« Reply #6 on: September 21, 2018, 03:03:58 am »
Charging for a years is not good for LiIon isnt it? It is RESERVE battery it charges every time
That is a larger problem with NiMH rather than lithium.
Lithium batteries degrade in relationship to their fully charged voltage so if you want longer life, the float charging voltage can be lowered sacrificing some capacity.  Whether they (or NiMH) cells will provide the service life you need under any conditions is a different matter and will depend on the specific battery.
