If anybody is curious, I just disassembled an old AMD adapter I had lying about - photo attached.
The device used is a 24C164WI from CSI. The closest I could find is this part from mouser:
CAT24C164.
For some reason, this part is a 2Kbyte part, which seems odd considering its purpose. This made me consider some kind of bizarre security/encryption system, but upon dumping it appears to be mostly empty - it could definitely fit in a 24C02. Considering the production volumes, I would have expected the bean counters to make this substitution. I only presume they had a large surplus of this part from another product, or found a very cheap source.
Also attached is a dump, in case anyone wants to make a clone (also note the chip lives at 0xA0-0xAF, implying A0, /A1 and A2 are low). The interesting part is only 17 bytes long, and consists of:
0x41 0x4D 0x44 0x01 0x00 0x0B 0x36 0x31 0x34 0x30 0x30 0x36 0x33 0x35 0x30 0x30 0x47
This is the text 'AMD', then 3 separator bytes, then the text '6140063500G'. This almost matches the serial number embossed on the housing, which is '614006350
1G'. Just to be sure this wasn't a read error, I checked again, so perhaps the machinery at the factory got out of sync?
I am curious as to whether this number is used for anything, and whether it is unique per device. If anyone else can tell me what number is embossed onto their adapter, I would be very interested.
