Another boring thread about Why using a curve tracer for matching JFETs is a good idea ?
Before i start to be boring i will only say that simple setup containing a voltage source and multimeter will let you measure some basic parameters and for most applications it will be sufficient and more than enough to use this method . If is this the case than dont bother to read all the boring stuff and grab a cup of tee instead .
Now il start with realy boring stuff and show some examples of how limited one point or few point measurements could be and how the measured values are prety relative.
Long story short - is that i needed a matched pair of high quality low noise JFETs for preamp imput stage .
For the job 2SK170 GR was chosen . I wasnt in a mood of monkeying around and searching for genuine toshibas on ebay so iv got LSK 170A from Linear Systems.
As for measuring setup i have used 2 Precision SMUs ,- one For Vgs suply the other for Vds.
To save me some time i started with Vgs voltage =0 and swept Vds from 0 to 10V Vds in 200mV steps.
Than i was puting gathered data into spreadsheet. Now i could sort measured values into the bins and select pairs acording to Ids values.
A litle note here. All the transistors came from one batch and were paired looking at the spreadshhed so i wasnt knowing how the curves will compare .
Now i could take a better look at the curves for selcted pairs. I had no intentions to dive into uA range so 3 curves should be sufficient for comparrisement purposes .
The Vgs voltage for each curve was suplied as follows 0V, -0.1V, -0.2V
Vds voltage was swept from 0V to 10V with 200mV step and here are the results :
Note the Id difference in the omic region and difference in Id for different Vgs values @ 10V Vgs
For a comparrison i have putted pair matched to 0.25mA
And at the end as alittle bonus a cuves for a pair of LSK 170A and LSJ74 .
There is totaly nothing wrong with the batch or with the quality of the transistors and i wasnt picking bad matches to show all this , i tried to match the transistors based on Id values and demonstrated how limited multimeter measurement setup is,- compared to curve tracer .
And yes i was able to match some nice pairs with no problems at all, but it wouldnt be possible without a curve tracer .
Everything what i have said or showed here is nothing new and has only informational character
Good luck to all in your future projects
