I have posted before about an awkward problem drilling aluminium enclosures that had PCB guides, but that was a fairly rare occurrence. Something I regularly have to do is drill 1.5mm aluminium panels, mostly the end panels of a hammond alu enclosure. Skip down three paragraphs to get to the point
As I only have to do 3-5 of these at a time, my usual tactic - without a pillar drill - is to glue a printed out template (done in eagle CAD believe it or not) onto the plate, use a 1mm bit in a pin vice and do a few turns just to get a dent in the exact spots, then drill 2mm pilot holes. From this holes are 3-6mm, and for a Dsub, 4 x 4.5mm holes at the corners, and then dremel out the middle, finally, file to a reasonably good Dsub shape.
It is time consuming, and for the most part it works rather well providing I am rather careful, take my time, and use a step drill for widening holes larger than 3mm. I have no idea how many of these I will need to do for the future because my customer seems to randomly call me up and ask for some so I am hesitant to invest anything for future orders. Also I barely make £10/hour on this, so on principle I'm not willing to fork out 100 on a pillar drill just yet. Right now its the only 'machining' job I have, the rest are all design or PCB population.
I have an order for 8 now, which is probably two days of drilling, and my purely 'manual' approach seems lengthy and depressing, so I thought I would invest at least some time in making a drilling jig, as all the panels are identical.
The panel only requires 8 holes (two large holes, and 6 for the Dusb - 2x3mm + 4x4.5 for the actual Dusb shape) some of which are very close together. My (simple) idea is an MDF block with 4 steel dowels and two threaded rods. The steel dowels are where the panel mounting holes are, and use to align the bottom MDF block to the top drill jig, the threaded rods are there so I can use wing nuts to hold the top part down - sandwiching the plate between. Its all doable and fairly simple but the real question is: what material to use for the drill guide?
Would high density MDF be ok for a drill guide? Perhaps 10mm+ (all the holes will be 3mm) or is there a relatively cheap way of getting a steel block made up? I know there are drill bushes, but I have yet to see any under $8, and for 8 holes thats $64. Also, I suspect this will only be used for 8 panels (I can stack them to drill 2-3 at the same time) so it doesn't have to last. All the drill jigs I've seen on google are either plain wood, used for wood working, where I suspect precision isn't vital, OR... full on 12mm steel plate with dirll bushes, very rugged and precise.
Does anyone have any examples of effective drill jigs they use with hand drills?
