Author Topic: Another Small Util for Rigol DS1000: Rigol Recorder (Vector Movie?)  (Read 1728 times)
Offline MechatrommerTopic starter
  • Country: my
  • reassessing directives...
i need a quick and interactive way of documenting and analyzing my project testing. so i build this to record whats on the scope. later i can play it back, insert some image and diagram notes, and compare with other testing setup. rigrecorder.zip is the app file (tested in WinXP). if you have not installed the externall dll required (those mbmp*.dll stuffs) then its patch.zip. if you still cannot run (COMDLG error) download and run the setup from http://www.soasystem.com/eng/goltek/setup100.zip you can test the app using sample test file rigol_recorder_test_file.zip (unzip the content). cheers.
« Last Edit: November 25, 2012, 07:40:43 pm by Mechatrommer »
Offline george graves
Re: Another Small Util for Rigol DS1000: Rigol Recorder (Vector Movie?)
« Reply #1 on: November 26, 2012, 06:13:28 am »
Cool stuff.  I don't know what I would use this for off hand - but it seems like it could be very useful!
