Author Topic: inductor value in a dc step up converter  (Read 2778 times)
Offline mariosTopic starter
« on: April 25, 2011, 03:07:22 pm »
I built an dc converter and first i used a 47microfarad inductor but then i change it and used a higher value 170microfarad,
is it possible to have less input power when i am using a higher value of inductor? but the output power of the converter at the same loading condition to be the same(1.5 W) with both inductors.
thanks
Offline tnt
Re: inductor value in a dc step up converter
« Reply #1 on: April 25, 2011, 03:32:17 pm »
quick note: Henry ... not Farads
« Reply #2 on: April 25, 2011, 03:38:34 pm »
yes sorry my bad!!! i was in hurry, anyway
so what you suggest, is what is happening correct?
Offline mikeselectricstuff
    • Mike's Electric Stuff
« Reply #3 on: April 25, 2011, 05:04:11 pm »
I built an dc converter and first i used a 47microfaradhenry inductor but then i change it and used a higher value 170microfaradhenry,
thanks
Yes, if the 47uH was saturating, or the 170uH has lower DC resistance.
Day Job: Mostly LEDs
« Reply #4 on: April 25, 2011, 06:30:40 pm »
thanks mike, and again sorry for the mistake!!
