Author Topic: Anti-Static Conductive Box  (Read 7514 times)
Offline onemilimeterTopic starter
« on: December 13, 2012, 09:29:32 pm »
Today I received samples from Microchip. The samples were stored in a black plastic box (with "MICROPAK ANTISTATIC" words printed on the box). Inside the box there are two pieces of high-density foam. I can confirm that the foams are conductive. I wonder if the black plastic box itself is conductive (for antistatic). Anyone can help to confirm this? Many thanks.
Offline free_electron
    • SiliconValleyGarage
Re: Anti-Static Conductive Box
« Reply #1 on: December 13, 2012, 09:59:39 pm »
stick an ohmmeter to it. if its black plastic most likely you will read something in the order of a few tens of kiloohm.
« Reply #2 on: December 13, 2012, 11:43:01 pm »
I used a Fluke 12B multimeter to test the resistance between two points on the surface of the black plastic but the reading was "OL" (open circuit). But when the same multimeter was used to test the black foams which came inside the Microchip sample box, it recorded few kilo-ohm. What do you reckon?
« Reply #3 on: December 14, 2012, 02:58:05 pm »
Static dissipative plastics typically have resitivities in the 10's of megohms per square. You need to use a meter capable of measuring gigohm resistors. Otherwise apply a high voltage to the one side and check if there is any current flow in the order of uA through it.
Offline Baliszoft
  • Country: hu
« Reply #4 on: December 14, 2012, 03:46:56 pm »
I got lots of these microchip micropak antistatic boxes.
The foam inside measures around 1 MOhm per cm and the box itself is 100-200 kOhm per cm. For me.
Offline T4P
  • Country: sg
    • T4P
« Reply #5 on: December 14, 2012, 05:17:58 pm »
Baliszoft, that's a bit odd.
On the foam i'm reading 5kohm/cm and the box is 0.22kohm/cm
Offline Baliszoft
  • Country: hu
« Reply #6 on: December 14, 2012, 05:40:12 pm »
Well, re did my measurements. Depending on the pressure i applied on the probes, i could get down to ~20k on the box, but there are places where it is a lot higher (around the 200k). On the foam, i could get down to 0.6 MOhms with a lot of pressure (i got it out of the box, otherwise it can be easily punctured giving false reading (the resistance of the box)).
All in all it looks like to be antistatic.
Offline Sionyn
« Reply #7 on: December 14, 2012, 05:52:09 pm »
they make green stickers to absorb moisture for shoe boxs (very hand to have in guitar case)
http://www.micropakltd.com/pdf/Micor-Pak%20Stickers%20-%20Instructions%20for%20use%20(Update).pdf
eecs guy
« Reply #8 on: December 14, 2012, 09:23:59 pm »
I think you're right that my multimeter is not capable of doing the job. Will try to get a better multimeter from lab to test it. Thanks.
« Reply #9 on: December 14, 2012, 09:25:58 pm »
Glad to know that the black plastic box is "conductive"... Thanks.
Offline NiHaoMike
    • Facebook Page
« Reply #10 on: December 15, 2012, 02:18:18 am »
A simple way to detect very small currents with an ordinary multimeter is to simply set it to voltage mode. Then touch a 9V battery to the object to be tested and measure from another point on the object to the other terminal of the battery.
Offline T4P
  • Country: sg
    • T4P
« Reply #11 on: December 15, 2012, 02:38:31 am »
How much current can the U1252B source? IIRC my UT61E i was using for the test can source quite a lot of current compared to most measly DMMs
« Reply #12 on: December 15, 2012, 09:15:13 am »
Just watched the EEVBLOG #247 video. I still don't quite understand the ESD... Let's say there are two bags, denoted as Bag-A (which is non-antistatic) and Bag-B (which is antistatic, e.g. the pink bag shown in the video). If both bags are rubbed together, will charge build up on BOTH bags? Also, if Bag-A rubs against itself, will charge build up on Bag-A?
Thanks.
