Author Topic: Any good books on history of EMC ?  (Read 3868 times)
Offline JolleTopic starter
« on: April 19, 2016, 01:36:38 pm »
Can anyone tell me if there exist any good books on the topics of EMC history? What I am looking for is a book that contains some information about how the EMC limits have evolved and why they are where they are today, information about the different test sites how they work and what separates them and some information about the different test equipment typically used when performing the EMC tests and why they have been choosen as they have (antennas, LISN networks, etc.).
Thank you in advance  :)
Offline sarepairman2
Re: Any good books on history of EMC ?
« Reply #1 on: April 20, 2016, 01:01:28 am »
Paperback: 352 pages
Publisher: Columbia University Press (June 28, 2011)
Language: English
ISBN-10: 0231131356
ISBN-13: 978-0231131353
http://www.bookfinder.com/isbn_search/
« Last Edit: April 20, 2016, 01:03:49 am by sarepairman2 »
« Reply #2 on: April 20, 2016, 09:11:53 am »
Are you insinuating that the EMC community is deeply corrupt and all standards are based on the desires from the people with most power? Or am I missing something?
Offline T3sl4co1l
    • Seven Transistor Labs
« Reply #3 on: April 20, 2016, 09:36:41 am »
Well... a few standards (probably the less important ones, but probably the more esoteric and numerous ones too) will have come directly from whole companies, sort of as a means of specifying their product.  And in turn, limiting their competitors.
(One of the prime economic goals of regulation is to insert barriers to entry: if it's more expensive for you, it's more expensive for your competitor; but if you get to set the rules, you have a leg up on them.  And barriers in terms of direct costs, capital, and development time, limit the rise of new competitors, which is better for both you and your competitors.)
For example, the PDF standard obviously was invented by Adobe, and now it's ISO.  (Nevermind that Adobe's relentlessly buggy design made it into the standard, so that it is not possible to implement a truly standards-compliant viewer, let alone one which is secure in any meaningful way.)
I think I heard that some of CISPR came straight out of Philips, but I don't know to what extent, nor how true, that is.
As for practicalities:
EMC itself is based on radiators and susceptibility.
Radiators need to be below a certain level, with unintended radiators being low across the range, and intended radiators being allowed a certain amount more, only at limited frequency ranges.
Meanwhile, susceptibility needs to be tolerant up to some level, which is above the level of most intentional radiators, and many decades above the level of unintentional radiators.
This ensures that:
- Unintentional radiators do not cause malfunction of other devices
- Nor cause impaired reception for radio services and communication devices
- Intentional radiators do not [usually] cause malfunction of other devices
- Devices are capable of failing gracefully under disruptive conditions from strong radiators and environmental events (such as ESD and surge).
The customary levels are (ballpark) < 1mV (e.g. conducted via AC line) for an unintentional radiator, versus 3V (conducted, or 3V/m radiated) tolerance for susceptibility.
Intentional radiators are usually under a watt (e.g., free/ISM band devices like CB, FRS and Wifi), so not too much induced voltage at a modest distance.  And of course, registered radiators going up to whatever they're licensed for, but there are fewer of those, and only licensed for allowed locations (fixed or mobile), so if you're in the area of one and your otherwise-compliant devices start to malfunction, well that's just kind of what happens.
Now, the matter of testing, at a nationally accredited lab, performing tests in line with every possible country's versions of these rules, is rather expensive.  But that's not an anticompetitive measure undertaken by greedy lobbyists -- it's an anticompetitive measure which arose as an emergent property of individual greed.  Everyone wants to sue for the littlest thing, so if you have the fancy notarized papers saying you did your due diligence, it ultimately saves more money in the long run.
TLDR: Afraid I don't have any history, sorry.
Seven Transistor Labs, LLC
Offline MikeW
  • Self confessed noob
« Reply #4 on: April 20, 2016, 10:37:22 am »
Not a book but you could do worse than look here http://www.laplace.co.uk/downloads/3/
« Reply #5 on: April 21, 2016, 02:59:09 am »
sometimes specific equipment is specified by national standards
agilent technologies: wat u got for me???
Offline CatalinaWOW
« Reply #6 on: April 21, 2016, 03:23:41 am »
A google search on history of EMC standards gives a plethora of results.
The following seems to give a lot of what you want.
Introduction to Electromagnetic Compatibility, 2nd Edition
Clayton R. Paul
ISBN: 978-0-471-75814-3
1016 pages
January 2006
http://www.wiley.com/WileyCDA/WileyTitle/productCd-0471758140.html
At the price, I would hope someone here has actually used it before actually buying.
Offline skipjackrc4
« Reply #7 on: April 21, 2016, 04:11:24 am »
Clayton R. Paul
1016 pages
January 2006
There is some history in this book, but it's primarily about theory and measurement techniques.  That being said, it's among the best written textbooks that I've ever read.
« Reply #8 on: April 21, 2016, 06:21:18 am »
Clayton R. Paul
1016 pages
January 2006
Most google seaches will give you "a plethora of results" but it is not every time that the results you get is what you are looking for, hence my question on this forum  ;)
But thank you all for your comments so far. I will see if I can get my hands on the "Introduction to Electromagnetic Compatibility, 2nd Edition" book too see if this is the book I am looking for.
Offline Tomorokoshi
« Reply #9 on: April 21, 2016, 05:07:54 pm »
There might be some useful bits of information here:
http://www.emiguru.com/
