People were reporting on this for YEARS.
I begun suspecting something might be going on when there was a sudden flood of "Havana Syndrome" stories that weren't muffled by the MSM.
It looked like a flood of decoys to drown the real info.
One obvious recent example was Kamala Harris, claiming she was targeted and had "Havana Syndrome" effect.
Since she is obvious avatar of the Deep State, who'd want to attack her BRAIN ? 🙄
But there were many posts online with some technical detail, suggesting what's going on.
There were many claims, suggesting it is being not just R&D-ed but used on a massive scale across 14EYES:
Remember RF BrainScan (if not, check whole thread below):
Newsflash: It looks 5EYES are hastily stitching it together between them.
As Ukraine is about to fall, they are hardening fallback area: whole South&East EU and its human swarm networks...
https://x.com/AKenabi/status/1688662703039025152Not that long ago we began to see what's going on, when globalists presented the tech publicly on DAVOS 2023 (check the whole thread!):
Hackable humans at WEF: ‘We can decode faces in your mind, your PIN number to your bank account'
https://x.com/AKenabi/status/1616205076808273939Basic principles are known.
At least two sub GHz carriers that get directed to the brain via phased array where they mix and their difference (and perhaps sum?) gets detected and analyzed.
They have to be high enough frequency so that they can be conveniently steered and focused, but low enough so that absorption by skin, skill and brain fluid is not to high.
Initial patent from 1970s was done with two beams in the 100MHz range, but they did not have the need for concealment, nor the convenient HF tech.
Epicenter of the testing ground seem to be in the East and South of EU- all those vassal states from Italy (west) to Ukraine (West) and Albania (south).
Whole area is basically open concentration camp with shallow top facade of "governments" etc.
They are ideal place for testing as workforce is highly qualified and cheap and whole repressive apparatus and MSM is under total external control.
So the place is safely distanced and isolated. Shit is unlikely to hit the fan and if it does, it's unlikely to hit the main culprits, global "humanitarians" etc.
It appears that this is the primary reason why all those supercomputer clusters were installed there - to train AI on the data while being out of sight.
UN has suddenly decided to declare "supercomputer clusters" as a basic human rights and started projects to install a few across those exact vassal microstates a couple years ago. 🙄
So, tech appears to be everywhere, but we still have no open source version.
Anyone here with the more tech data to share ? 🙄
