I have a question for those in the field.
recently, I went in for an eye exam to update my glasses. its been a few years since I did that and my left eye needed more correction (in my current glasses).
we did the usual exam; they project the same letters (sigh) on the wall and have you read the lowest line you can make out. I don't like this test (for lots of reasons) but I follow the dr's procedure since he seems to think this is the best way to find your needed correction.
ok, he tries various len combos as he dials in this huge swing-arm mounted rotating set of diopter step-lenses. 'is one better or two? is three better or four?'. the usual thing (at least in the US, that's how they do it).
my issue is that we ordered the eyeglasses, the lenses were correctly ground but when I tried them on and had the new frames adjusted, the left was still not optimal. I asked if we could try putting some fractional diopters in front of my left eye and if the 1/4 helped, lets just add 1/4 to the left and reorder the lenses. using that sample 1/4 lens on my right did not help and actually made things worse, so I concluded my right is already properly corrected but the left needed an extra 1/4.
the doctor does not believe me. I think he does not like that I questioned his 'big expensive machine'.
what do people in the field think about this? I've found that the machine that they put against your face is NOT what you wear every day (lol) and so its a -starting point- but its not gospel. once they order lenses and frame them, then adjust the frames so it sits evenly on your face, the distance between your eye and the lens can have an effect. this is the last step in finding the -true- value of correction you need, given the lenses and frames you bought.
if you are in the field, I'd like to hear your comments on my experience. I did finally convince the doctor to order a new left lens for me, but he clearly didn't want to and I was frustrated having to argue with him. my eyes don't lie and if that 1/4 extra helped, why argue with me, the patient?
