I know with webcams, as long as it follows the UVC (usb video class) standard, it will run out of the box, without installing a driver provided specifically for the camera. Same thing with USB mice and keyboards. They use a standard that lets them run without you needing to install drivers from a CD (or company website download).
Is there a similar standard for USB to serial converters, that allows them to work out of the box, without installing a driver (just using the default driver that comes with Windows)? If so, can you list some decent USB to serial converters that follow this standard? Like what companies are known to make such "driverless" USB to serial converters? I'd like to know, so I can look them up by name on Amazon.
