Those standoffs may be useful some day.
I give all dead motherboards and PCBs the heat gun treatment
to collect: connector sockets, quartzes, jumper pins, heat sinks
(no longer any more, as I don't need so many), LEDs,
those low ESR capacitors (used after testing of course)
Great stuff for mucking around and oneoffs I personally use.
I also reuse stripped ATX power supply enclosures. Saves me doing
some metal work since the mains power socket is already there.
The PCB mounting holes are also very welcome. Also the metal is not that thick
And these enclosures are neatly stackable since their size is standardised.
