Author Topic: Anybody used one of the cheap Ebay DC ATX PSUs?  (Read 1360 times)
Offline Mechanical MenaceTopic starter
« on: June 24, 2015, 04:03:58 pm »
I recently realised I have my main PC running almost all the time just for web browsing, text editing, and HTPC usage so I've been looking at getting a passively cooled mini ITX system with an integrated CPU to cut down on noise and energy use. So I thought this would be a perfect time to get rid of an inverter and get a DC PSU for the new system. After a quick search I came across an awful lot of these:
http://www.ebay.co.uk/itm/DC-12V-24pin-ATX-160W-Pico-PSU-Auto-Computer-PC-MINI-ITX-Power-Supply-Module-/171809133347?pt=LH_DefaultDomain_3&hash=item28009f5323
http://www.ebay.co.uk/itm/Mini-ITX-160W-12V-PICO-PSU-DC-DC-Power-Supply-ATX-Board-24-pin-/121669445862?pt=LH_DefaultDomain_3&hash=item1c541068e6
very similar boards. Has anybody used one and if so what experience have you had with it?
Second sexiest ugly bloke on the forum.
"Don't believe every quote you read on the internet, because I totally didn't say that."
~Albert Einstein
Offline Stray Electron
Re: Anybody used one of the cheap Ebay DC ATX PSUs?
« Reply #1 on: June 24, 2015, 06:17:39 pm »
   I have a bunch of them that I salvaged out of some PCs that were used aboard ships to operate a Iridium based Glove i4 communications system made by Global Wireless.  They all work fine.  They came with a bunch of 12 VDC 5 Amp (IRRC) wall warts.  Hmm, I just looked at one of the computers and the back panel says "12 VDC 1.8A".  The mother board is a VIA EPIA-EK.   I don't know about the quality of the ones on E-bay but these look just like them and everyone that I tried out works fine.
  PS I just pulled out one of the 12 VDC supplies to look and see if it was marked the same ("Z2-ATX-160") as the 2nd one on E-bay. It's not. This says "Mini-Box.com" on it so you might want to check there. (Markings aren't the same but they may still be made by the same company.)
« Last Edit: June 24, 2015, 06:29:31 pm by Stray Electron »
