I did purchase the larger of the two new landscape lighting fixtures
I mentioned a few posts ago in this thread. I like it! It's significantly
brighter than my previous lighting and seems to be holding up well.
Inside the house, I'm struggling to find lights for two applications.
The first is a nightlight which is a ball with a rice paper shade.
It came with a 7w CFL, which is OK, but too bright for my
intended use. I've been looking for an LED replacement with
a candelabra base (E12 in the US).
The best I've been able to come up with so far is this
50 lumen 2 watt bulb from Osram Sylvania:
I've also been searching for lights for a bathroom fixture that looks
kinda like this:
I've tried my favorite Home Depot 40w LED replacement bulb, but it's too
directional for this fixture. I've also found that it has a different dimming curve
than the incandescent bulbs. So if you mix the bulb types then dim them,
you'll have one kind of bulb going out far before the other. Should have been
obvious in retrospect, but I didn't think of it.
Scott
