Author Topic: Arduino looking for problems to solve  (Read 1870 times)
Offline soldarTopic starter
« on: May 12, 2024, 10:26:48 pm »
45 years ago I was programming 6502 in assembler and I found plenty of applications. I did data logging, a phone dialer, access control, and a few other things. I always found plenty of things to do.
Fast forward 45 years and I am totally out of the microcontroller world and I want to get into it. I started a thread asking and finally decided to get started with Arduino.
I have had it for two or three months now. I have played a little. Did the blinking LED thing but just cannot get myself motivated to keep learning in the abstract.  I need to find a concrete project, a concrete problem to solve and I just cannot think of anything I need to solve with an Arduino.  I am stuck.
I cannot think of any data I want to log or anything I'd like to control.
The closest I can think of is a gate access control with a weatherproof keyboard to input a code but in my experience weatherproof keypads are expensive, unreliable and short lived. Probably not worth it. For a moment I thought it might be fun to have my street gate with a rolling code so I could give a code to the neighbor and it could only be used once.
Or, I have a crate full of IR remote controls.  Maybe use one and decode the signal with the Arduino to then control ... I don't know what. I have nothing that needs a remote control.
Can you think of something practical, useful I could do with the Arduino? Unless I can think of some practical and useful project I am afraid the Arduino will languish in a drawer forever.
Online xrunner
  • hp>Agilent>Keysight>???
Re: Arduino looking for problems to solve
« Reply #1 on: May 12, 2024, 10:58:55 pm »
I think it's been said here several times - everything that can be done with the Arduino has been done now by someone. That doesn't mean what has been done is of any use to you or me in particular. I'd look at the sensors available to you instead of the "Arduino" itself. What can you sense or control with the sensors available that could perhaps be made into a project you would use or enjoy? If you can't think of anything then let it languish until you do.
A couple of the things I played with recently that I wanted to do was sense an animal getting into my garden and spraying it with water, and sensing how far my car was into the garage so I'd know when to stop the car exactly. Turns out neither of them ended up using an Arduino (or shall we just say microcontroller). The animal sensing thing was too finicky outdoors and the car parking solution was easier just to simply aim a red laser at the dash when the car was parked where I wanted it (much less complicated). However I still keep thinking of projects.
For example, the last good project I did with Arduino was sensing the input and output temps from my indoor HVAC unit and displaying the temps and differential on a display on the door. That one was good enough that my neighbor begged me to make him one.
So keep thinking it'll come to you when you least expect it.  :-+
Online themadhippy
« Reply #2 on: May 13, 2024, 12:19:35 am »
combine the 2,ir remote controlled gate lock
a tennis ball hanging down that touches the windscreen when in the perfect position is a  less power hungry solution
Online xrunner
« Reply #3 on: May 13, 2024, 12:31:06 am »
That's what I had before, but I lay awake at night thinking of high-tech solutions to things. At least I dropped the Arduino from that project.  :-DD
Offline pcprogrammer
« Reply #4 on: May 13, 2024, 06:31:58 am »
It al depends on what your other interests are. For instance, do you like musical instruments? If so, you can dabble with synthesis. Or if you like mechanical systems, you can create something with motors or servo's.
But I can understand your predicament, I myself also need dedicated things to do, or else it stays on the shelf. I used an Arduino nano to control a central heating mixing valve to lower the water temperature from the storage tanks to what is more appropriate for underfloor heating. I used a bluepill in the same system to double the serial communication channel the main controller, a raspberry pi, had available. Recently I used STM32F103C8T6's for a remote control system. All practical solutions, not just blinking some LED's.
Offline Berni
  • Country: si
« Reply #5 on: May 13, 2024, 09:20:14 am »
Going on a home automation mission tends to spawn a lot of MCU requiring projects.
Even if you don't automate anything, it can also be interesting to measure things around the house. Like monitoring where the power is going so that you can have nice graphs of how much power was used to aircondition the house. If you have things like fuel tanks, rainwater tanks etc.. it can be interesting to monitor the level of those. You can add in a flow meter into your water supply..etc
Otherwise robotics is a major user of MCUs. Can be anything from a line follower to a robotic lawn mower or one off mechanical projects (like a machine for putting patterns on easter eggs in some fancy elaborate way)
« Reply #6 on: May 13, 2024, 10:34:29 am »
I could hang the Arduino instead of the tennis ball :)
That would be a permanent reminder that I need to do something with it. :)
The following users thanked this post: xrunner, Roehrenonkel
Online xrunner
« Reply #7 on: May 13, 2024, 10:57:55 am »
Yes but make sure it's hanging from a power cord so it can be there blinking an LED.  :-DD
The following users thanked this post: soldar
« Reply #8 on: May 13, 2024, 12:01:26 pm »
Thanks for all the comments. I guess some decades ago I had more interest in automating things, logging data, etc. and now I just don't have that much interest. I have some lights on timers and that is the extent of my "home automation".
I have meters on the refrigerators and that is mainly because I have the meters.
If I could think of something entertaining or funny, even if useless. Something interesting to talk about. A showpiece...
If I could think of something useful as a gift for someone else... but I can't. Common needs are already met by commercial devices.
Some months ago a friend was dumping a clothes washer because the main control board was bad and it was so costly to replace that he decided it made sense to buy a new washer. But a clothes washer is just a tub with a motor and some valves and sensors and you could probably control it with a simple microcontroller, even if you can only get a single, simple program. My friend would not need anything more. Too late for that though as the washer was already recycled. It would have made for a fun project though.
I guess I'll have to keep thinking.
Online xrunner
« Reply #9 on: May 13, 2024, 12:18:48 pm »
Entertaining and useless showpiece? Oh you need to look into 3D LED cubes for Arduino - just google it.
Offline Nominal Animal
« Reply #10 on: May 13, 2024, 01:02:49 pm »
Think about decorations and gags.
With digital RGB LEDs (WS2818 and similar), you can do nice simulations of fire and plasma effects.  I outlined the base implementation here.
Gags often involve a small servo, like in the "Useless Box", which has a single toggle switch on it.  When you toggle the switch, a small servo activates, so that a hidden lid on the box opens up, and a "finger" pushes the toggle back off, then retreats back inside.
In Halloween/Dia de las Brujas -type props, a small TFT display can be used to display an eye, with movement (like blinking) or change of the eye, or the eye "turning" in different directions triggered by sensors or a timer.  These are often called "Uncanny Eyes".  Adafruit has a project overview on these.
If you have pets, making a pet-safe "chase me" -toy, or other (perhaps servo-based) toys takes some thinking: you definitely don't want them to bite into a battery, for example.
Offline RoGeorge
« Reply #11 on: May 13, 2024, 01:48:38 pm »
Batteries.  :)
Log/diagnose battery packs from laptops and alike, to see the voltage on each cell, real capacity, current, etc.
Saying this because I've just made an unintended SMBus battery reader for Dell, while trying to reverse engineer out of curiosity another RAID cache backup battery from a HP server:  https://www.eevblog.com/forum/projects/looking-for-the-pinout-of-the-li-ion-backup-battery-battery-in-hp-gen10-servers/msg5496463/#msg5496463
Weather station, log temperature, humidity, air particles, radiation level, etc.  Add some 2.4GHz wireless modules with nRF24L01+ (they are dirt cheap, 50 cents or so).  As Arduino boards use Arduino nano, same MCU as UNO, but smaller footprint, can be fitted to a breadboard, and they cost less, about $2 a piece.
It all depends of what interests you.  Most probably by now you have most of the needs already covered, and anyways, would be cheaper to buy something ready made to cover whatever need you may discover you have, rather than to build it from scratch.  So, either find a funny/entertaining project for you to build, or make a sidestep and go into another hobby where you don't already have all the tools you need.
Maybe you like moving things, make a line follower robot, or some reversed pendulum robot walking vertically and balancing itself on only two wheels.
Or maybe you want to build something nobody heard before, build a RoGeorge analog yet digital multiplier.
https://hackaday.io/project/7542-rogeorge-cell/  (shameless plug  ;D)
« Last Edit: May 13, 2024, 03:40:37 pm by RoGeorge »
Offline Peabody
« Reply #12 on: May 13, 2024, 02:30:45 pm »
There is also an Arduino forum that might provide some ideas.
https://forum.arduino.cc/index.php
Offline armandine2
« Reply #13 on: May 13, 2024, 02:52:30 pm »
I have an arduino project on my to do list  :palm:
read a particular [somewhat expensive] handheld infra red "remote" controller with a view to recreating it
Funny, the things you have the hardest time parting with are the things you need the least - Bob Dylan
Offline mendip_discovery
« Reply #14 on: May 13, 2024, 05:26:27 pm »
How about you lend your talents to project that could do with some help getting that extra bit further along with the project.
Motorcyclist, Nerd, and I work in a Calibration Lab :-)
So everyone is clear, Calibration = Taking Measurement against a known source, Verification = Checking Calibration against Specification, Adjustment = Adjusting the unit to be within specifications.
Offline DimitriP
« Reply #15 on: May 13, 2024, 09:39:18 pm »
Yup.
Tons of people needing help at the arduino forum...and luckily they haven't discovered this place here yet :)
Take a look there  and don't bring them back with you ! ;)
« Last Edit: May 13, 2024, 10:34:05 pm by DimitriP »
Offline tooki
« Reply #16 on: May 13, 2024, 10:03:20 pm »
One project I have in permanent use is a giant-digit thermometer (with outdoor temperature probe) I made using LED filaments, LED drivers with individually dimmable outputs (controlled via I2C), controlled by an ESP32 microcontroller programmed with Arduino. Using the LED drivers means I can do things a traditional 7-segment LED driver (like the BCD-to-7-segment drivers in 74- and 4000-series logic) cannot do, like fading segments in and out (with 97kHz PWM!), using just a single I2C bus. It supports multiple temperature sensors, including the DS18B20 and a precision I2C one. It also allows viewing the temperature and updating the firmware via WiFi. (Which I eventually need to do when I get around to writing the code to enable the ambient light and gesture sensor that’s also built in.)
« Reply #17 on: May 13, 2024, 10:05:50 pm »
Thanks! This looks very interesting and promising!
« Reply #18 on: May 13, 2024, 10:08:07 pm »
These ideas are in line with the 3d cube which I think I like best but these also might come later. Thanks.
Offline Peabody
« Reply #19 on: May 14, 2024, 03:51:41 am »
I suspect many over there feel the same way about the EEs here.
Offline vidarr
  • Country: br
« Reply #20 on: May 14, 2024, 12:36:51 pm »
No, I don't think too many over there know about over here. I hope it stays that way.
Most of my projects are with Arduinos, but I moved over here for a reason. You guys rock.
Offline vidarr
  • Country: br
« Reply #21 on: May 14, 2024, 12:47:37 pm »
If you garden, or farm, there are a million and one different projects you can make with your Arduino. Someone mentioned sensors above. There are so many sensors excellent for gardening/farming.
Eventually, Id' like to make a guided missile. Maybe make a drone too. I make fun of the FPV guys and their goggles, but it's actually pretty fun. That has got to be at least 10 months of fun project and play.
Back to the missiles... I'd like to make a working S-500 (toy), for taking out drones (toys).
Offline rstofer
« Reply #22 on: May 14, 2024, 02:31:09 pm »
Start nibbling around the edges with sensors, motors, displays, etc.  Starter kits provide gadgets and code that can be ported to more complex projects
https://www.amazon.com/ELEGOO-Project-Tutorial-Controller-Projects/dp/B01D8KOZF4
« Reply #23 on: May 14, 2024, 05:17:33 pm »
If you switch to microcontrollers with native USB –– Teensies, Pro Micro clones (ATmega32u4), ch552g ––, you can do your own USB HID device; from keyboards to mice to joysticks.  Doing it via serial driver emulation is lame in my opinion: the native USB HID requires no drivers and works in all OSes just like bought ones.  (If you use Chrome 89 or newer, Edge 89 or newer, or Opera 75 or newer, you can do games as web pages, no server or network connection needed, that can directly access the HID events from any USB HID device, via the WebHID API.  Say, creating a version of old Pong, using two rotary encoders or potentiometers.)
One I'd like to do is a full 3D ball controller, with all movement detected.  (Compare to a trackball, where rotation around the vertical axis is not detected/supported.)  I can easily handle the math, but I haven't found affordable documented optical mouse sensors to do it with (it needs two).  I could use magnetic field sensors and a ball with one or more magnets inside it, too, but optical would be nicer.
My very first microcontroller project was an arcade plank (stick and buttons using microswitches just like in old arcade machines) and a 4-bit encoder to select the mapping to keypresses, using AT90USB1286 (Teensy 2.0++).  This was in the era of lots of web-based Flash games (platform puzzle ones were my favourite).
I do have parts for an e-ink display with capacitive touch sensor, so I can make a reprogrammable macro/tool keyboard, perhaps with scroll/pan support (when you drag instead of poke at it).  Currently, I don't use enough different programs to warrant that, as in Linux the keyboard shortcuts are user-configurable (especially in Inkscape, Gimp, LibreOffice, etc. with many options that I often use), so I just adjust the keyboard shortcuts to my needs, and don't really need a separate macro pad.
Online SiliconWizard
« Reply #24 on: May 14, 2024, 09:18:09 pm »
A 3D mouse controller is one of the projects that sits on my list.
Another one is a small wireless network of simple devices (sensors, displays) with sub-GHz radio.
