Author Topic: Are R core transformers a thing?  (Read 5839 times)
Offline Echo88
Re: Are R core transformers a thing?
« Reply #25 on: March 18, 2025, 04:45:16 pm »
A quick follow up for people searching for shielded transformers.
After the r-core teardown which revealed the shield winding fraud, i recently tore down a shielded toroidal transformer to check whether this one actually is shielded correctly as claimed, before buying more transformers for a project.
Manufacturer is apparently Toroidy and i bought the transformer some 1-2 years ago from reseller MPAudio (now out of business it seems):
https://sklep.toroidy.pl/en_US/c/Toroidal-transformers-AUDIO-GRADE/75
Very happy to see the primary completely surrounded with the copper shielding and a magnetic soft seel ribbon wound around the secondary under the black mylar tape.
CM-noise measurements have not yet been made on it.
Offline floobydust
« Reply #26 on: March 19, 2025, 03:01:55 am »
Can you measure the capacitance to the shield and between the windings?
I find these toroids will couple mains RF to the shield/chassis ground, due to the high capacitance.
R-core does not suffer this, their construction is very low winding capacitance to the core, which might be why they are liked in audio circles.
