As a dead resistor, usually only in analysis when doing series-parallel transformations. Resistors in series add; conductances in parallel add. The reciprocal of the sum of the reciprocals is...
And yes, transconductance amplifiers (that is, current out, voltage in) are rated in Gm. A BJT's small signal transconductance is gm = Ic / Vth, for example.
