The ninja-edit timeout is precisely 90 seconds.
I have a bunch of posts edited in the 91st second so it would be nice if this could be raised retrospectively to 100 seconds
For a while the 1st attachment was somehow appearing in other posts one made like it was still somewhere in the system and linked to you and came out when you made a subsequent post.
Darn annoying it was as you always had to edit posts to delete it and for some time the only workaround was not to use the first attachment. Bit me a few times so just skipped the first attachment and all was well.
This seems suspiciously similar to the
weirdness described by pcprogrammer.
I'm not 100% sure how it was earlier, but currently attachments uploaded in the first line are uploaded immediately (and it's possible to upload a few, they appear as a list below the first upload line). If you don't post, they stay around and attach to the next post
Maybe something similar was already happening earlier. Wasn't it a fault of the "inline attachment" plugin that Dave installed and later disabled? Maybe it still is? I recall Dave saying that he has updated this plugin to the latest version a few days ago. Maybe that's where the drag&drop box comes from, too.
At any rate, I haven't had such problems.
But... I tend to block 3rd party scripts, which includes JQuery downloaded from
code.jquery.com. So it's possible that this buggy plugin simply never worked for me and that's how I stayed out of trouble
Indeed, if I block scripts from this domain now, the drag&drop box disappears, and the 1st attachment line works for me like in traditional SMF. The only difference is that I still see the "inline thumbnail/image" options, which insert
[ Attachment Invalid Or Does Not Exist ] into my post and then nothing happens because it's all broken as we know.
