Please, no, not Xenforo. Or anything else which insists I can only use one third of my display.
Themes dictate this, not the forum software.
Most allow users to choose between a fixed width and full width. You can also pick the colour of the theme.
Hell, you can even have multiple themes. Would not be too hard to emulate this old theme and make Xenforo look alike.
Agreed. This is the main thing that has been missing from this forum: an easy way to add/manage pictures to a posting. If I want to attach more than 1 image, I use an image hosting service but for many of my early postings the images are long gone.
But you know that you can attach up to 10 files, up to 5MB total?
This has always worked, it's only inlining which is screwed up.
It becomes a pain if you have multiple images as you can only select one at a time.
Modern editors will allow you to drop them in, move around and resize them. So much nicer than all in the footer.
This is not good for archiving though. All posts with Photobucket photos for example are useless now.
Really, all photos/images should be hosted on the forum unless absolutely necessary.
Less load time for users as well. 1 less DNS lookup.
