Fine, disabled. Everyone happy again?
I'm pretty convinced that no matter what changes I make to the forum, people are not going to be happy.
That only cost me a decent lunch to try.
I wish you'd left it on for more than a few hours so that more of us could have tried it. Most of us literally did not even get the chance to try it once. And you know how it is: people that don't like something are FAR more likely to say something than people who like it.
Re-enabled so people can try it. I'll leave it there for a day or two.
SCEditor (the so called "new" editor) and can be tested online, with all its features maxed and working:
https://www.sceditor.com/SCEditor is a separate project, just like SQL or NGINX are not part of SMF, some of those features might not work in SMF, or they might interfere with other SMF addons.
Posting the link and suggesting for the curious to try it there first, because 2 years ago I've manged to break my SMF install trying to fix things that were not working as expected in SCEditor. That was a RPi with a SMF meant as an alternative to a blog-like and/or personal project repo but online, a first time install and could have been entirely my fault.
Now, after 2 years, weird things are still there, random example, when I press enter to add an empty line, a new line is created, but the text in the edit does not scroll up, so to see the empty line I have to use the mouse wheel. Back then there were many bugs. Many are are still present.
Block malwarescript from code.jquery.com and it's almost back to normal. Guess I'm going to do it for now.
Can you tell or point me to a link of how to do that, please? No idea if that's a checkbox in the options here, a Firefox setting, or a sysadmin setting in the firewall. Using Linux/Firefox, and Stylus to add a custom dark theme. I don't know much about javascript, CSS, HTML and alike, so don't know what should I search for.
