Author Topic: Are there any EEVblog server app you'd like to see installed?  (Read 18851 times)
Offline JPortici
Re: Are there any EEVblog server app you'd like to see installed?
« Reply #175 on: December 18, 2022, 07:46:37 am »
Ah, i haven't replied in a number of threads because the quote button doesn't work anymore and i don't want to bother doing it manually.
probably for the best?
« Reply #176 on: December 18, 2022, 10:04:11 am »
Does with W10 and Chrome.
Avid Rabid Hobbyist
The following users thanked this post: PA0PBZ
Offline JPortici
« Reply #177 on: December 18, 2022, 12:34:24 pm »
Doesn't work on firefox, osx and windows 10
Offline xrunner
  • hp>Agilent>Keysight>???
« Reply #178 on: December 18, 2022, 12:36:28 pm »
What's wrong with the quote button?
Offline JPortici
« Reply #179 on: December 18, 2022, 02:08:36 pm »
forever "Loading"
Offline Bud
« Reply #180 on: December 18, 2022, 03:12:21 pm »
Perhaps Win 10 issue? I have no problems quoting on iPhone Safari browser, Android Chrome browser, or Win 7 Chrome.
Offline JPortici
« Reply #181 on: December 18, 2022, 03:14:39 pm »
Currently on my macbook, which uses firefox.
I suppose chrome is not affected
Offline pcprogrammer
« Reply #182 on: December 18, 2022, 03:26:16 pm »
No problem on Ubuntu with FireFox.
Maybe some disabled/enabled script issue.
Online ataradov
    • Personal site
« Reply #183 on: December 18, 2022, 05:38:43 pm »
I already described what the issue is (post 169). It is with the site itself, so it would be the same for all platforms/browsers.
For everyone that says it works - you are not looking at the right thing. We are specifically talking about the embedded editor that you get by clicking "Modify message" icon under your post, not a big "Modify" button over the post.
It is literally a matter of fixing a couple quote marks in the javascript. The issue is fixed with manually injecting the fixed javascript using a browser extension, but this is just stupid.
« Last Edit: December 18, 2022, 05:41:04 pm by ataradov »
Alex
« Reply #184 on: December 18, 2022, 05:48:21 pm »
The way I read it is that JPortici has a different problem.
I interpret "Not replied due to the quote button not working" as clicking on the regular "Quote" button above someone else's post and enter the normal editor that way. Not using the quick modify editor, where you would have to use the "Insert Quote" button.
Edit: Yet he did manage to use a quote in message 179.  :-//
« Last Edit: December 18, 2022, 05:50:21 pm by pcprogrammer »
Online ataradov
    • Personal site
« Reply #185 on: December 18, 2022, 05:56:33 pm »
There are two issues with the same reason. Editing does not work and quoting does not work either.
For quoting we are talking about the same thing - quick reply editor under the thread. This is a forum setting, so if you have it set to open a.new window (with posts sorted in reverse and the editor at the top), then it would work.
Alex
Offline Ranayna
« Reply #186 on: December 18, 2022, 06:05:22 pm »
I think we are maybe not talking about the same thing here.
Hitting "Quote" with the Quick Reply section at the bottom open behaves differently to when the Quick Reply section is closed.
Since closed Quick Reply is the default, i think not many people are even using the feature. I wasn't even aware it existed before this thread came up.
Hitting with Quick Reply open gives that "Loading" bar and never does anything. Is Quick Reply closed, it opens the editor in a new page, and the full post is quoted.
Latest Firefox on Manjaro for me.
EDIT: Too slow  ;D
« Reply #187 on: December 18, 2022, 06:23:05 pm »
The quick edit thing is probably off by default. I never changed it, so my setting is from the day I joined the forum.
The standard way works fine for me so I will just leave it off.
« Reply #188 on: December 18, 2022, 07:15:47 pm »
No. Browser or PC settings issue instead.
Sooner of later it will be discovered just what the problem for some is.
Avid Rabid Hobbyist
Online ataradov
    • Personal site
« Reply #189 on: December 18, 2022, 07:19:58 pm »
Well, this is going in circles. This is a site issue. There is a error in the javascript. It can be easily fixed by adding a few quote marks. It is trivially fixed by injecting correct javascript locally.
If you don't have issue quoting, you don't have quick edit editor enabled as shows above. But everyone has an issue with in-line editing.
Alex
« Reply #190 on: December 18, 2022, 09:15:01 pm »
The forum has changed much over the years and we each have had to too in order to get the best from it.
Some are reporting the 1st attachment is still giving problems however it seems load attachments just fine for me however this 1st attachment is never 1st in the thumbnail list but fucking last !  :-//
So back to how we've used attachments for gawd knows how long now, only using the 2nd attachment and always skipping the first.
I don't imagine Dave is going to edit the code in forum plugins/upgrades.
If you can find workarounds I recommend you use them and get on with life.
Avid Rabid Hobbyist
Online ataradov
    • Personal site
« Reply #191 on: December 18, 2022, 09:37:59 pm »
I think the fix is to completely uninstall (as opposed to simply disabling) that halfassed editor. The errors are introduced by leftovers from that editor.
Alex
Offline JPortici
« Reply #192 on: December 18, 2022, 09:42:57 pm »
because it works in the full editor :)
the issue i'm seeing is in the quick editor, the quote button on the upper right of any post.
But i'm not going to go to the full editor to quote a post from three pages earlier, that i have to find in the list of recent replies, which isn't there anyway.
Here the quote button has stopped working the moment the quick editor was reverted from new to old
edit: just for kicks, i tried in safari, that i never use because it's a shitty browser, so i don't have ublock installed, or any other plugin. same issue: hit the quote button of upper right of post, forever loading.
« Last Edit: December 18, 2022, 09:47:48 pm by JPortici »
Online SiliconWizard
« Reply #193 on: December 18, 2022, 10:15:02 pm »
This is odd. I don't get that. How do you quote then?
Online ataradov
    • Personal site
« Reply #194 on: December 18, 2022, 10:21:36 pm »
You don't get it because you don't have quick reply editor enabled in the forum profile settings.  When you press "Quote" you get redirected to a new page with an editor and this works. The issue is with the setting where page remains the same, but the quoted text is added to the quick editor box.This functionality is implemented through javascript that is currently broken.
Currently I don't quote at all.
Alex
Offline PlainName
  • Country: va
« Reply #195 on: December 19, 2022, 12:28:01 am »
But I do it all the time. You just go to that post and hit quote. Or mark the bit you want, copy, hit reply then the 'insert quote' button. How is the instant reply thing (at the end of the thread) any simple or quicker? The one time I tried it I found it loathsome - no way out of it if you changed your mind and didn't want to post.
Online ataradov
    • Personal site
« Reply #196 on: December 19, 2022, 12:35:59 am »
Set aside the style of quoting. Everyone has preferences. But inline editing for a quick typo fix is faster and easier. And that is broken too.
Plus with the full editor you have to look at that row of stupid animated emotes.
Alex
« Reply #197 on: December 19, 2022, 01:42:39 am »
What's that ?
If you use the Modify message button within the post body there are zero emojis.
Edit to make changes.
« Last Edit: December 19, 2022, 01:50:25 am by tautech »
Avid Rabid Hobbyist
Online ataradov
    • Personal site
« Reply #198 on: December 19, 2022, 01:44:21 am »
There is zero emojis, but it also does not work. It disregards the changes and redirects you to the first page of the thread. That's the whole problem.
Alex
« Reply #199 on: December 19, 2022, 01:52:20 am »
Yes it does for you not many others of us. See above.
I think you might need to rebuild your browser or OS. Try a few other devices.
Avid Rabid Hobbyist
