Author Topic: Are these components?  (Read 1619 times)
Offline msuffidyTopic starter
« on: May 23, 2023, 03:06:49 am »
I have a PCIe card that does weird things it seems the more I use it, including disappear from the system.
I was looking at the PCB and I noticed these gold bowties. They look kind of like spark gaps, but they are not gaps, are they fuses or something? Maybe they indicate where the spark gaps are sort of looks like (my camera magnified it so I can see).
« Last Edit: May 23, 2023, 03:09:37 am by msuffidy »
Offline helius
Re: Are these components?
« Reply #1 on: May 23, 2023, 03:50:14 am »
They could function as a PCB fuse; but also they control the thermal conductivity between different areas of copper fill, which can be useful for soldering for example. On old computers like the Apple II, "bowties" were used for circuit options the user could modify with an x-acto knife.
Offline boB
    • my work www
« Reply #2 on: May 23, 2023, 04:05:21 am »
Could they be modifiable areas where you might want to cut those connections for certain reasons ?
Since it looks like one power plane to another, I'm thinking that is why there are so many.
boB
K7IQ
The following users thanked this post: wraper
Offline thm_w
  • Non-expert
« Reply #3 on: May 23, 2023, 09:22:36 pm »
Its a net tie to connect two nets electrically but allow you to automatically have a clearance gap on the copper pour.
Since they have the exposed copper they could also work as a test point, or as previous say make it easier to cut with a knife.
https://smtnet.com/library/files/upload/NetTies-and-How-to-Use-Them.pdf
Offline Infraviolet
« Reply #4 on: May 25, 2023, 07:59:33 pm »
How did those "bowties" remain as exposed copper during manufacture, and not end up with tin/HASL/ENIG/gold or whatever other plating was used covering over them? Most production processes have everything which isn't covered by solder mask plated with one of those covering to make them easier for parts to solder on to.
Offline T3sl4co1l
    • Seven Transistor Labs
« Reply #5 on: May 25, 2023, 08:32:06 pm »
OSP (organic solderability preservative) -- keeps the bare (unplated) board clean enough for production purposes (6 months or so shelf life, give or take?).
Seven Transistor Labs, LLC
Offline trophosphere
« Reply #6 on: May 26, 2023, 03:06:15 am »
Maybe they add Peelable Soldermask before the plating step and then remove afterwards?
Offline ebastler
« Reply #7 on: May 26, 2023, 06:17:50 am »
Pretty sure they are ENIG surfaces. The color may not come across clearly in the photo, but the OP describes them as "gold bowties".
Offline strawberry
  • Country: lv
« Reply #8 on: May 26, 2023, 06:46:17 am »
fools gold?
Offline T3sl4co1l
« Reply #9 on: May 26, 2023, 10:29:50 am »
Have seen it before on a laptop motherboard, here mostly holes, but some solder jumpers appear on the bottom side.  This was after like 10 years in use, so they've aged to a darker orange color, comparable to the tantalums -- which I think are tantalum polymer perhaps, not the regular yellow kind.  It's not a camera trick, they are darker than usual, and no it's not a heat+age thing, at least I don't think it is; there are yellow ones elsewhere.  As well as aluminum polymer chip, and either can poly or electrolytic elsewhere too.  They certainly went for diversity in here...
https://www.seventransistorlabs.com/Images/8510W_1.jpg
https://www.seventransistorlabs.com/Images/8510W_2.jpg
Offline Whales
    • Halestrom
« Reply #10 on: May 26, 2023, 10:58:01 am »
Just as an aside: also be wary of PCIE switch chips on the motherboards themselves.  Perhaps they only trigger problems for certain cards.
