Author Topic: Arrgghhhhh BAD Manufacturing  (Read 2516 times)
GeekGirl
  • Guest
« on: February 15, 2010, 09:37:54 am »
Hi all,
A customer bought a Lumatek digital 250W HPS ballast (these are used instead of magnetic ones for lighting)
It did not come with an output lead, so I was asked to convert it to an Au round earthed pin socket. I opened it up expecting to see a PCB terminal block, or crimp pins soldered into the PCB, Not the mess I found :(
This is brand new.
I was going to look at reverse engineering it, but I can not with this mess :( I did notice a vertical PCB in the middle of the main power board, so it seems it has a custom module :( I have looked for schematic on the net and not come accross any for MH or HPS globes :(
Excuse the image quality, it was done with the camera phone ;)
Offline DJPhil
Re: Arrgghhhhh BAD Manufacturing
« Reply #1 on: February 15, 2010, 04:40:23 pm »
That's a lot of goo, I wonder if they're trying to make double sure it'll last through it's warranty at 100%RH.
I've only dealt with these sorts of ballast once, but I think they might have specific output requirements.
I found this writeup from ST, will this help you any?
