I'm using different brand wheels next time. The ones I use have plastic axles, and it's that slippery kind of plastic nothing sticks to. So to get the silver paint to stick, I have to use a Dremel to rough a pathway across. The resistor gets stuck on with a dot of CA, that sticks to anything. ANd it has to be a TINY dot - if it gets on the metal end caps of the resistor, you've just insulated it! I had a very high success rate though, considering it was my first attempt. Next time I will use a different brand of wheel, which has a metal axle, and just a small insulated bushing on one side. Resistor goes diagonal across the bushing and the paint connects the end of the resistor to the wheel on one side and the axle on the other, much easier. And I was using 18% silver paint, I may step up to 36% - the primary use of the paint I got is for scanning electron microscopes, amazingly enough.
