Author Topic: testing trans  (Read 2004 times)
Offline kjn4685Topic starter
testing trans
« on: September 26, 2014, 02:59:50 am »
Is it possible to test a transistor with a oscilloscope I hope that this is the right place to post
« Last Edit: September 26, 2014, 03:31:58 am by kjn4685 »
Offline David Hess
  • DavidH
Re: testing trans
« Reply #1 on: September 26, 2014, 03:31:48 am »
Not directly but an oscilloscope in X-Y mode can be used as part of a curve tracer.
Re: testing trans
« Reply #2 on: September 26, 2014, 03:33:22 am »
Ok how would I do this.
Offline fpliuzzi
Re: testing trans
« Reply #3 on: September 26, 2014, 05:32:53 am »
kjn4685,
Alan (w2aew) made a video where he demonstrates how to make and use a simple oscilloscope based component tester. If you're curious check out the following thread...
www.eevblog.com/forum/beginners/dirt-cheap-and-simple-scope-based-component-tester-curve-tracer/
Offline GreyWoolfe
  • NW0LF
Re: testing trans
« Reply #4 on: September 26, 2014, 12:06:51 pm »
kjn4685,
And it works quite well, also.  I made a little printed circuit board for it and mounted it inside a case along with a 5Vdc power supply for a multitasking box.
