Author Topic: ATN Channel 7 Sydney / Quantel Paintbox Oddity  (Read 1900 times)
Online dexters_labTopic starter
« on: August 22, 2017, 04:24:08 pm »
I have just been working with one of my quantel paintboxes, specifically using Kryoflux to image some old 8" floppies and i just noticed a label on the drive which seems to be a ATN Channel 7 Sydney asset number!
Looks like this drive used to be at Channel 7 Sydney, the drive is dated 1986  :-//
bizarre though this drive supposedly came from BBC Elstree Studios here in the UK  :wtf:
strange how tech gets moved all around the world!
Offline Halcyon
  • Global Moderator
Re: ATN Channel 7 Sydney / Quantel Paintbox Oddity
« Reply #1 on: August 22, 2017, 11:03:23 pm »
How do you find the Kryoflux by the way? I've been looking at getting one.
Offline SL4P
  • There's more value if you figure it out yourself!
« Reply #2 on: August 23, 2017, 01:18:17 am »
Probably swapped / traded-in by Quantel - and ended up going back to UK as spares for other projects.
Often we'd see UK tech support staff out here for installation / upgrade work.
Don't ask a question if you aren't willing to listen to the answer.
The following users thanked this post: dexters_lab
« Reply #3 on: August 23, 2017, 05:57:20 am »
it seems to be an excellent well thought out product, it does seem to be struggling with the quantel disks though but that's not really a fault on the kryoflux side
in it's stream preservation mode it will create what is best described as a bitmap image of the flux changes on the disk. This means you can make a perfect copy of it, whatever it's format. I don't believe any disk imaging tool has done this before.
It can also decode and create binary data images of the disks with profiles detailing FM/MFM encoding, RPM, sector numbers, sizes etc, which create image files like you'd normally expect.
The problem we have with the quantel disks is if you want Kryoflux to do the MFM decoding then it will look for sectors, but the quantel disks are not sectored so it won't give us any data. We're hoping we can tell kryoflux not to do anything fancy and just MFM decode the track(s) for us. I'll have to see what their community says.
It's biggest annoyance to me is it needs Java Runtime if you want to use the GUI  :scared:
Offline Halcyon
  • Global Moderator
« Reply #4 on: August 23, 2017, 11:03:04 pm »
Thanks for that. On paper it does look like a very good product. It's just a shame that it doesn't come in a box as opposed to a bare board.
« Reply #5 on: August 24, 2017, 08:37:57 am »
yes lack of box is a bit of a shame
