Author Topic: TENV Motor Internal Fan: Required?  (Read 847 times)
Offline jpanhalt
« on: March 27, 2017, 05:07:18 pm »
I have a TENV fractional HP (1/6 HP) Leeson motor on a septic aerator.  The bearings froze and are shot after just 2 years.   The armature has a plastic internal fan that makes removal of the armature and replacement of the end bearing difficult.  There is no external capacitor.  The fan can probably be removed with a little heat, but I am worried about getting it reattached well.  Of course, I would use Loctite if I get to that point.
Question:  Is the fan really necessary?
John
Offline tpowell1830
Re: TENV Motor Internal Fan: Required?
« Reply #1 on: March 27, 2017, 05:35:25 pm »
TENV - Totally Enclosed Non-Ventilated (for the young players out there)
IMHO, no, you could leave it off for all pracitcal purposes.
PEACE===>T
The following users thanked this post: jpanhalt
Offline Benta
« Reply #2 on: March 27, 2017, 06:32:34 pm »
I disagree. Noone puts a fan there without a reason.
Note that the fan is internal, and probably serves to eliminate local hot areas by circulating air within the motor.
Externally, the motor is TENV, but that's another issue.
Offline jpanhalt
(SOLVED) Re: TENV Motor Internal Fan: Required?
« Reply #3 on: March 27, 2017, 07:55:33 pm »
SOLVED
I as able to get the fan off without heat or damage.   Will re-install with a little Loctite.  I would rather re-assemble as built.  My fear was that if the fan got damaged in the process, it is not a part I can buy retail.
Thanks all for the advice.
John
