Author Topic: Aviation airport geolocation  (Read 1746 times)
Offline soldarTopic starter
« on: April 20, 2019, 02:19:29 pm »
In another thread someone posted a photo of a sign at an airport gate giving the geographical coordinates. I looked it up on the map and found some discrepancy and so I posted asking but got no reply or interest in that thread. I am still curious as to why the geographical longitude marked at airports do not match the WGS84 coordinates. Anyone?
Where was that photo taken? At first sight I guessed somewhere in SE Asia but putting those coordinates (10º 49' 06''N, 105º 54' 43''E) into Google it takes me to a rice field in South Vietnam.  I guessed the most probable error was in longitude and found Ho Chi Ming City airport at the same latitude but about 45 NM to the east.
Sign says: 105.911944°,
This page gives 106.62965,
This page gives 106.652,
Google Earth says 106.66034.
Maybe the airport is moving around?
This photo's coordinates also do not match. The longitude is off by a certain distance.
Internet sources confirm Google Earth uses WGS84 datum and aviation uses the same datum (as you would expect). I am very curious about this. Maybe some aviator can explain the discrepancy.
Offline CatalinaWOW
Re: Aviation airport geolocation
« Reply #1 on: April 20, 2019, 04:57:10 pm »
I know that there is much misdirection about "important" sites for a variety of reasons.  Maybe someone considers an airport "important".  In any case I am not sure the strategy is well thought out.  A sophisticated entity trying to reach one of these "important" sites would not be inconvenienced greatly.  Perhaps the decision makers were/are living in the past where simple subterfuges might be enough to hide something.
Offline awallin
« Reply #2 on: April 20, 2019, 06:28:04 pm »
can't find much wrong with the one in Spain, google places a pin right next to "05"
https://goo.gl/maps/sJFQTKXQZFw42or38
Offline awallin
« Reply #3 on: April 20, 2019, 06:47:20 pm »
googling landed me a picture of stand 16 - which seems to have roughly correct coordinates according to google  :-//
https://goo.gl/maps/5QnkNBdgDpxT25mx7
« Reply #4 on: April 20, 2019, 06:51:41 pm »
You are right. I must have made a mistake the first time around. I believe to main example is still wrong though.
« Reply #5 on: April 20, 2019, 06:52:39 pm »
No, those are signs located at airport boarding gates so that pilots can zero their navigation systems. They must be good for whatever purpose they are supposed to be.
An interesting case is China where official maps are distorted and the coordinates differ from WGS84. Using a GPS receiver in China is illegal (although the truth is nobody cares) and cameras and other devices sold in China must disable the GPS receiver when they detect they are inside China. IMHO it is crazy because, come on, America probably has better maps of China than China does. I really don't see what good it can do to them.  https://en.wikipedia.org/wiki/Restrictions_on_geographic_data_in_China
Offline donotdespisethesnake
  • Embedded stuff
« Reply #6 on: April 20, 2019, 08:27:09 pm »
I would question the provenance of the photo. Clearly the longitude is wrong, but according to my investigation Tan Son Nhat International Airport does not have a Gate 10. The airport was remodelled in 2007, so maybe there used to be, although that still would not explain the wrong coordinate.
Before concluding all airport gate location signs are wrong, I would look for some known good data.
Update: gates 10-14 are described as "bus gates", i.e. passengers are taken by bus to plane on the apron. I'm not sure those are fixed locations, so I'm still not convinced this is a genuine sign.
« Last Edit: April 20, 2019, 08:32:01 pm by donotdespisethesnake »
Bob
"All you said is just a bunch of opinions."
« Reply #7 on: April 20, 2019, 11:06:32 pm »
As the second photo turned out to be correct it may be this is just a bad photo somehow but I am still curious. I can't see why anyone would alter a photo like that.
I did find the photo online when I searched last time but cannot find it now.  Maybe Shutterstock or similar service.
The difference in longitude is about 0.75º = 45' It does not seem like it could be a simple transcription error because several numbers would need to change.
Maybe it is a single case and not a widespread thing as I first thought.
« Last Edit: April 21, 2019, 07:46:27 am by soldar »
Offline jc101
« Reply #8 on: April 21, 2019, 10:59:00 am »
Well I posted that original pic which I just grabbed from Google Images as an example, no idea where it came from, it was just to show an example of what happens in aviation.
Here is an example of charts, for Heathrow in this instance, where the stands and main areas are all referenced with GNSS coordinates.
« Reply #9 on: April 21, 2019, 03:24:01 pm »
When you first posted it I searched and I found it somewhere and checked. Then I found another one and checked and I found it to also be mistaken and that is what sparked my curiosity.
Now I find out I was mistaken with respect to the second one which turns out to be correct.
So the scope of the question is greatly reduced from "why are all signs (I have found) wrong" to "why is one sign (which we can't even find now) wrong".
