Wow, beautiful. I'm very jealous that he figured out how to implement this so well. Both the mechanics and software for this are hard.
I wanted to save local copies of the video. Search vimeo for "a million times" found:
vimeo. com/60491636 A million times (Time Dubai) by Humans since 1982 The original
vimeo. com/60333036 Humans Since 1982, a million times Similar, copied by someone else. Silent
vimeo. com/60824954 A MILLION TIMES Another. different view and music
Also Anna von Hausswolff - Mountains Crave youtube. com/watch?v=QbP--RsNj70]
Music to the 'a million times' clock
I've wanted to make an analog clock with independently, identically driven hands for ages, but the mechanics is hard in a hobby workshop. Needs two identical fine gears on the sleeved hand-drive shafts, with worm gear drive from tiny stepper motors (such as used in floppy disk drives.) A bit beyond my machining abilities, and so far I didn't find anything suitable commercially.
But the really tricky part is arranging separate index sensors for both gears, with sufficient accuracy to allow the hands to be lined up visually perfectly. Since the eye is so damned good at sensing a slight kink in a line, the index sensor has to be accurate to a tiny fraction of a degree. it's noticeable that some of the hands in that array are a little off sometimes, so I guess he didn't entirely solve that either.
I wonder if he's using a separate small processor per unit? It seems likely. Perhaps with unit IDs that are an X,Y coordinate, and a command broadcast syntax that allows description of 'waves' across the X,Y space, so individual units figure out for themselves what they need to do.
(Edited to stop the auto-URL insertion of videos. Remove spaces.)
