Author Topic: Axial fan inserts  (Read 1188 times)
Offline veedub565Topic starter
Axial fan inserts
« on: November 10, 2023, 08:09:36 am »
I'm replacing an axial fan which has threaded inserts fitted for mounting it. I can't find a suitable replacement with the same threaded insert fitted. Yes I know I could put a nut the other side instead, but the location of the fan in the equipment chassis makes this very tricky to do.
I spoke to Orion fans who confirmed this is an OEM option with MOQ of 500. Obviously I'm not going to do that.
Anyone know if it's possible to buy these inserts separately ?
Online Someone
    • send complaints here
Re: Axial fan inserts
« Reply #1 on: November 10, 2023, 09:09:35 am »
TIL rivnut ?
The following users thanked this post: veedub565
« Reply #2 on: November 10, 2023, 09:47:52 am »
Yess, thanks that's the ones
« Reply #3 on: November 10, 2023, 10:16:25 am »
or even a threaded rivet bush
Offline themadhippy
« Reply #4 on: November 10, 2023, 11:04:16 am »
glue the nuts to the fan before fitting the fan
The following users thanked this post: BrokenYugo
Offline Gyro
« Reply #5 on: November 10, 2023, 07:41:05 pm »
Watch out for any kind of rivet nut/bush, you're liable to split the plastic.
Best Regards, Chris
Offline TERRA Operative
  • Country: jp
  • Voider of warranties
    • Near Far Media Youtube
« Reply #6 on: November 14, 2023, 12:36:01 pm »
I'd look for an aluminium rivnut so it requires less force to set, and make sure the crush area is not inside the flange on the fan when inserted.
Many rivnuts are designed for sheet metal, so the crush area is located accordingly.
« Reply #7 on: November 30, 2023, 07:51:46 am »
I actually managed to reuse the old ones in the end. I bashed them out with a drift, and used a vice to press them into the new fan. Bit of a faff but worked ok.
Fan has a metal chassis so no plastic to split.
