Edy,
I have some allergy myself and I can't handle too much candles. So I need emergency lights to avoid wife needing too much candles. Humidity will hit my breathing but I can deal with that better than candles. I can see where you come from. Let me share some experience with you - particularly my "open hood rapid charging" method.
If you have not already obtained your battery, there is some significant pluses to car battery over marine/deep-discharge. Particularly those "Portable Jump-Start Battery." They don't hold as much charge (mine is 22AH verses typical small car batteries in the 25-30AH range). The "portable car jumper/starter" are the kind with built in car jumper-cables and some has CLA (cigarette lighter adapter) built-in. Some even have inverter build-in for 110v. Almost all have battery-level indicator light or gauge. They are design for starting cars, so they are well prepared for high Amp discharge -- which means they likely can take on high-Amp rapid-charging easier and more conveniently. A regular car-battery "on the side" can do that too, but you can't walk it around with the same ease and none has battery gauge built in (that I know of). I use external CLA-plug inverter so I can drag the portable jumper-battery where ever I need it easily and switch between my two jumper-batteries.
When you connect the jumper-cable to a car with engine already running, the car's alternator will charge the jumper battery - rapidly because the battery is design with more plate area for rapid discharge. I connected my jumper-battery to the car's battery (while the engine is running). With the car's alternator pumping out (I think) 60+ Amps , my 22AH jumper-battery was fully charged in well under 30 minutes with engine at idle.
I do not recommend the alternatively of using a CLA-to-CLA adaptor cable connecting the car's CLA socket to the batteries' CLA socket and charge the portable battery that way. My portable battery came with such a cable. It can be done, but between the alternator and the car's CLA, too much is in between to cause a fairly high voltage drop by the time the juice gets to the car's CLA socket. Also, the car's CLA socket has a lower current limit. This CLA-to-CLA method was not working well for me so I put a DMM in between to see why. I can see unless the engine is at fairly high RPM, my portable battery was actually discharging into the car. The jumper-cable right at the car's battery terminal give it a almost-direct connection to the alternator. It works like a charm and do so quickly.
With my two jumper-batteries, I can take them out to the car with ease and charge by car-jumper connection. I switch battery every 5 minutes or so - to let the charge settle and to do a voltage check while the other battery is charging. I do that for around 30 minutes and both my batteries are near 90% full. The batteries will start to gas if overcharged. Gassing voltage depending on temperature, you want to stop charge at about 14.2volt. I use 14.5v as my hard-stop.
During Sandy (the storm), I got caught unprepared. I was determined not to get caught again. With my two jumper-batteries, one good and the other too old to start a car. Both my batteries were on LOW at the start of Sandy and I didn't know exact what that means. ***Know your battery*** After the storm, I did full charge and discharge tests with the batteries. I used time-lapse photo rather than sit there and watch. Now I know the voltage each battery-level light coming on, and how many more AH can it still put out. When the 2nd to last battery level light is still on (or when first switch to the lowest light). I have 50-60 watt-hours (@ 2-3A)left in good battery, and about 20 watt-hours on my older battery. About 1/2 that in watt-hour if I push it to 4-5A discharge. Note, means 1/4 the time. 1/2 the stored watt-hours, but twice the amps meaning 2x the draw rate giving you 1/4 the time. I use voltmeter/dmm because the exact voltage give me more accurate estimation of watt-hour remains than the "hi mid-hi, mid..." indicator lights on the battery.
I also measured the current drain on my must-have's and my like to have's. So I know with confidence "I can wait till next day to do an open-hood jumper or until the rain stops". I have hard data based on battery voltage how many Watt-Hours I have left on the stuff I need/like to run. I know unless both batteries are at bottom-level light, I have 8+ hours of what I consider "survival minimum" with a 10% margin, and I plan to do another discharge test again in a year since batteries do age.
1. If you already have regular car battery (batteries), think about getting battery carrying-straps or those travellers' luggage "pull cart" like the ones airline employees use (to take the batteries to the car), and get car jumper cables. Now you know you can easily charge as long as you have some gas in the car.
1a. If you already purchased a car battery, do consider adding a portable jumper battery. That could be your "last line of defense" and it is darn portable. My small one was $30 (8-10yrs ago) with 7AH at walmart. Not good for car-starting anymore since it is rated at 300CCA only, but great as emergency battery.
2. With portable car jumper batteries, you can charge it so easy and self-discharge is so low, I think you really don't need trickling. A top-up every 3 months would do the job nicely. It will lengthen battery life. I rather use up the battery life during emergency than trickling it away.
3. Get those car-volt meter that plugs into the CLA and/or a DMM. Don't leave the meter plug in but keep it handy (my CLA-voltmeter drains at 30ma). You need at least 2% accuracy +- 1 decimal is good. 1/2 volt difference on the SLA may mean a dead battery verses one that can run your stuff for yet another few hours.
3. Get some RV/camper LED lights with CLA and a long cable - they are efficient and very useful when you need to hook-up for "open-hood rapid charge" at night. I made a few of them, just G4 socket with 8 feet wire into a CLA adaptor. Those are my primary emergency lights. I can connect that to the hood and do my "open-hood rapid charge" in the night.
4. Take time to know your battery (batteries) - how long to charge, and a voltage vs watt-hour-remain table. Watt-hour will depend on current draw. At least do one with your minimum need (lowest amp to survive). You can do another one say with comfortable needs included.
5. CLA (for your must have) is more efficient than inverter. If getting CLA for your must have's adds up to too much, don't oversize your inverter. You may be wasting a lot of mAH running the inverter electronics if you oversize your need.
Hope this is useful info to you.
Rick
Stay healthy... good luck.
