Author Topic: Bad Electronics Jokes  (Read 43252 times)
Offline niconiconiTopic starter
  • Country: cn
« on: April 20, 2022, 07:43:56 pm »
Some terrible electronics and computing jokes I made over the years, some people at here may enjoy them.
Q: A linear regulator has a power efficiency problem and asks for help. What did the switched-mode power supply answer?
A: Have you tried turning it off and on again?
Q: Why has the hardware developer stopped eating junk food recently?
A: Because of chip shortage.
Q: What do you call a hardware developer who accidentally plugged 5 V logic to a 3.3 V UART port?
A: A serial killer.
Q: Why does Shahriar Shahramian need a lab cat for The Signal Path?
A: It's all about meowlimeter waves.
Q: What do you say when a microcontroller dies?
A: /RST in peace.
Q: Why does the amplifier refuse to work?
A: It demands proper compensation.
Q: What do you call when the White House or the Congress keeps changing its official stance back and forth?
A: Washington AC.
Q: Why do digital design engineers always have extremely busy jobs?
A: They have to work around the clock.
Q: Why can't a high-speed transmission line find a job?
A: It must be terminated.
Q: Why did vector voltmeters become obsolete?
A: They don't solve real problems.
Q: What does an EEPROM become during the pandemic?
A: A Mask ROM.
Q: What do you call two network operators in an unhealthy relationship?
A: A twisted pair.
Q: What do you call a monopole antenna when it was patented by Marconi back then?
A: A monopoly antenna.
Q: What does an amplifier says when there's a lot of high-frequency noise in its power supply?
A: "It Hertz!"
Q: What do you say when a sensor mysteriously stopped working?
A: It doesn't make sense!
Q: What do you say when a hardware developer is ignoring the signal integrity problems in the system?
A: Open your eyes!
Q: Why did YouTube demonetize a video lecture on control systems?
A: It's full of negative feedback.
Q: What do you call a programming language that only supports integers?
A: A pointless programming language.
Q: What do you call a secret conspiracy by a group of analog electronics designers?
A: The Bode Plot.
Q: What does a technician say when the multimeter gives a wrong reading?
A: It could just be a Fluke.
Q: Why do Ethernet transceivers always argue with each other?
A: Because they can't find a common ground.
Q: Why can't the UK just cancel Brexit?
A: The instruction "br exit" is an unconditional jump.
Q: What do you say when a new CPU vulnerability is announced but details are still under embargo?
A: I can make some predictions, but it's all speculative.
Q: What does a USB device say when it gets angry?
A: Am I just a J/K to you?!
Q: What does a hardware developer say when an EEPROM is accidentally erased?
A: What the FF?
Q: What do you say when a datasheet is missing important information or full of mistakes?
A: Datashit.
Q: What do you say when you reopen Matlab after it crashes?
A: The Matrix Reloaded.
Q: Why did a mathematician purchase a bunch of coils and transformers before writing the paper?
A: Proof by induction.
Q: What does an engineer say to an opamp when it's used as a rail splitter?
A: Hold your ground!
Q: Why did Scalar Network Analyzer become obsolete in electronics?
A: Because history is written by the vector.
Q: What is your job title when your electronics project is really boring?
A: circuit bored designer.
Q: What do you call a cheap step-down power converter that costs under $1?
A: A buck converter.
Q: What do you say when you've wasted many hours on a defective eval board?
A: Evil board.
Q: A radio engineer owns an airplane but it never leaves the airport, why?
A: For most RF circuits to work properly, you need a ground plane.
Q: What is the best job for a Low-Barrier Schottky Diode detector?
A: Wikipedia editor. Because it works without bias.
Q: What do you say when you are puzzled by a mysterious integer overflow bug?
A: It doesn't add up.
Q: What does an engineer say when an amplifier works but with some harmonic distortions?
A: Fundamentally, it's not really a problem.
Q: If you are making a series of tutorials on impedance matching, what should you say at the beginning?
A: Stay tuned!
Q: If you are making a tutorial on control systems, what should you say to your audience?
A: Your feedback is important!
Q: Why did an RF engineer go to Area 51 to work on an Ethernet system?
A: To solve the alien crosstalk problem.
Q: Why do you need a capacitor before start watching US politics on C-SPAN TV?
A: To protect yourself from DC bias.
Q: What do you say when a robot is broken after a Darlington power transistor failed?
A: The robot has bipolar disorder.
Q: How does an antenna designer solve an impedance matching problem with a Vector Network Analyzer?
A: Taking a moment of reflection.
Q: Why was the electronics manufacturing engineer fired from the job, but later became a successful architect?
A: for creating a lot of bridges.
Q: Why can't investors make a conclusion about the current 5G mobile chipset market?
A: They always get mixed signals.
Q: When do you say when a spy sold you top-secret technical data on x86 processor microarchitectures?
A: Good intel.
Q: What does an impedance analyzer say when you connect a capacitor to it?
A: Is it real or am I just imagining things?
Q: What do you say when a power supply is broken after its electrolytic capacitors have gone bad?
A: The power supply is incapacitated.
Q: What do you say when an engineer from Poland got paid after leading a labor dispute?
A: Dominant-pole compensation.
Q: What do you say when a broken PIN diode switch took down the RF amplifier?
A: No PIN, no gain.
Q: Why did a group of VCs refuse to invest in a startup company which is trying to build a new CPU?
A1: Too much RISC.
A2: Because it costs an ARM and a Lag.
Q: Why is it slow to send data over a serial port?
A: You have to go bit by bit.
Q: What do you say when your power supply supports remote sensing for cable voltage drop compensation?
A: Resistance is futile.
Q: What do you call when ham radio operators on the shortwave are talking about things to sell for hamfest?
A: High Frequency Trading.
Q: What do you say when people are talking about control theory and you don't understand anything?
A: I'm out of the loop.
Q: Why did the Analog Devices CEO power up a 7805 breadboard before purchasing Linear Technology?
A: The acquisition must be approved by the regulators.
Q: Why does the NIST have a large supply of Doublemint in its physics labs?
A: All measurement uncertainty must be calculated according to the GUM.
Q: What does an RF amplifier do after it's destroyed by an output open circuit by some clueless maintenance crew?
A: Suing for wrongful termination.
Q: What do you say when you're searching for a high-voltage circuit, and finally found a suitable design that looks promising?
A: It has a big potential!
Q: When the '\a' character on your Unix terminal doesn't beep, where is the best place to find an expert to solve your problem?
A: Bell Labs.
Q: Why did an embedded programmer rewrite a 100-line loop and joined them as a 10000-character single line in C?
A: The book said reducing loop area is the key to control electromagnetic interference.
Q: How do you describe the fact that low-side current sensing at ground is easier than high-side current sensing?
A: It's common sense.
Q: Why should you never allow an RF/microwave technician to test your embedded system?
A: Your system will get de-embedded.
Q: What does a motherboard designer say when the deadline is near but a high-speed signal problem caught them in surprise and the CPU is not working?
A: "Oh DDR!"
Q: What do you call when you have a lot of 7400 chips but you refuse to give or sell them to someone else?
A: Gatekeeping.
Q: What do you say when a buggy device keeps generating spurious interrupts, says something is there, but every time the CPU went to process it, there's nothing, and a lot of system resources is wasted?
A: The IRQ War.
Q: Why is the production of the BIOS chips delayed?
A: ROM wasn't build in a day.
Q: What do you say when an amplifier has unwanted lag in the feedback loop, but you still get some phase margin left?
A: instability can be a problem, but only to a lesser degree.
Q: What do you say when your Tektronix oscilloscope is broken, and it cannot be fixed on site so you'll have to live without the scope in the following days?
A: You have a "Teknical" problem, and your problem is "out of scope".
Q: What do electronics engineers do when they are asked to reproduce a software bug that crashes the system only after a 100-day uptime?
A: Placing it in an oven, heating it up to 125 degrees, and then apply Arrhenius Equation to it.
Q: What do you say when a purchase order of rigid coax cables gets delayed due to supply-chain difficulties, but the company insists the vendor to deliver it on time and refuses to renegotiate the terms?
A: "We are taking a hard-line stance on this problem!"
Q: A PCB designer spent a lot of time on optimization, eventually, even all the right-angle bends are carefully mitered to preserved the characteristic impedance. But the customer rejected the finished product, why?
A: "Look at the circuit board! See? They are cutting corners!"
« Last Edit: May 18, 2022, 03:33:56 pm by niconiconi »
Offline metrologist
Re: Bad Electronics Jokes
« Reply #1 on: April 20, 2022, 08:06:36 pm »
OK, #2. To help our engineers, tomorrow I will be bringing in bags of Doritos, Lays, and etc. to help them cope with our chip shortage.
The following users thanked this post: Wallace Gasiewicz, DL2XY
Offline free_electron
    • SiliconValleyGarage
« Reply #2 on: April 27, 2022, 04:34:23 am »
What do you say to a digital designer that needs to synthesize and simulate everything before he understands it ?
More TTL and less VHDL.
Offline Zbig
« Reply #3 on: May 05, 2022, 12:57:01 pm »
Wow, you've set a pretty dry... I mean pretty high bar right there, but I'll bite :)
  • What is the technical university's analog electronics design faculty specializing in voltage regulator design most famous for?
  • Low Drop-Out
  • Audio design lab cat had two kittens. Their names?
  • Wow & Flutter
  • Why did a boutique audio shop switch to solid state?
  • They were tired of creating ideas in vacuum
  • Title of the documentary about leading DSP company researchers?
  • Fast and Fouriers
  • Why did nobody like this smartphone repair shop?
  • It was full of hot air
  • Why did all the DC power supplies fail one after another?
  • Ripple effect
  • What was the doctor's advice for a network technician's gastric problems?
  • More fiber
« Last Edit: May 06, 2022, 06:58:35 am by Zbig »
The following users thanked this post: niconiconi
Offline MK14
« Reply #4 on: May 05, 2022, 03:18:54 pm »
Q: What do you say, when a Microcontroller finally dies ?
A: Actually they are all made out of (Silicone) dies.
Q: A Resistor fell in love with a nearby female family member, what do you say ?
A: Resist-her.
Q: What to do if a Transistor, keeps on over-eating ?
A: Use a heatsink, to stop it over-eating.
Q: What Camera accessory, is best for shooting pictures and saving your pictures on ?
A: Flash gun
Q: What do you use, to make funny electronic foods stuffs with ?
A: Silly-con Wafers, or Silly-con Chips.
Q: How many homes, does a resistor factory worker need ?
A: Just one ohm.
Online NiHaoMike
    • Facebook Page
« Reply #5 on: May 06, 2022, 02:13:16 am »
I used to not consider AMD products, but then they had Ryzen...
Did you hear about the time Alayna Phillips connected a LED to a 10MHz oscillator? She considers 10MHz and below DC...
Latch up: when CMOS circuits go bipolar.
The Joe Smith 14kV DMM test: if it survives, it's a Fluke.
"So I used to really love diodes, but, I always felt like that feeling was one way!" - Xyla Foxlin
Actual experience with Agilent at work: you know it's bad when they send a rep over to explain that they're "out of scopes".
  • Country: cn
« Reply #6 on: May 07, 2022, 12:31:54 pm »
Q: How do you describe the process of impedance matching?
A: It's complex.
Q: Why are electronics engineers bad at cooking?
A: They use too much SPICE.
The following users thanked this post: MK14, jasonRF
  • Country: cn
« Reply #7 on: May 07, 2022, 12:37:15 pm »
Vendor-specific jokes:
Q: What do you call when you have Broadcom chips but can't really do anything without datasheets, which are all under NDA?
A: BoredCom.
Q: What do you say when a Realtek network adapter doesn't work?
A: Faketek.
Q: What do you say when a Richtek power management chip doesn't work?
A: Poortek.
Q: What do you say when the Allwinner ARM SoC has a silicon bug?
A: AllLoser.
Q: What do you say when an ASMedia PCIe controller is defective?
A: ASSMedia.
Q: What do you say when a Huawei HiSilicon chip has a lot of bugs?
A: LoSilicon.
Q: What do you say when a Huawei HiSilicon chip is damaged?
A: ByeSilicon.
Q: What do you say when a Huawei HiSilicon chip has high power consumption and runs really hot?
A: HiSiliconCarbide
« Last Edit: May 07, 2022, 12:41:19 pm by niconiconi »
The following users thanked this post: MK14, MrMobodies, TC
Offline MK14
« Reply #8 on: May 07, 2022, 12:43:28 pm »
Q: Which logic device keeps on making jokes?
A: A JK Flip-Flop.
Q: Which component can give you chemical poisoning, despite having no dangerous chemicals, in it?
A: LEDs, as they still aren't LED free yet.
« Last Edit: May 07, 2022, 12:45:31 pm by MK14 »
The following users thanked this post: rsjsouza, Zbig, MrMobodies
  • Country: cn
« Reply #9 on: May 07, 2022, 04:48:09 pm »
Q: What do you say when the management is always looking for the cheapest resistors and capacitors to cut costs?
A: The management is passive-aggressive.
The following users thanked this post: SeanB, MK14, MrMobodies
Offline MrMobodies
« Reply #10 on: May 08, 2022, 02:03:07 am »
Q: What chipset in around the 2000's behaved like a sissy?
A: The SiS 530
Q: What is the state of broadband in the UK?
A: Patchwork Britain.
« Last Edit: May 08, 2022, 02:22:26 am by MrMobodies »
  • Country: cn
« Reply #11 on: May 10, 2022, 07:10:00 pm »
Q: Why didn't an RF system vendor get many sales after advertising their products?
A: The ad says their performance is "unmatched".
  • Country: cn
« Reply #12 on: May 12, 2022, 09:34:21 pm »
Q: What do you say when you are selling electronics soldering kits for an 8-bit retro computer?
A: Some assembly required, just use the provided instructions.
The following users thanked this post: MrMobodies
  • Country: cn
« Reply #13 on: May 15, 2022, 11:08:36 am »
Q: What do you say when someone asks you how to build bandpass filters with a very high Q?
A: The solution should be crystal clear, you already SAW that in the book before.
The following users thanked this post: MK14, EEEnthusiast, jasonRF
Offline Teti
  • Country: cz
    • www.martenelectric.cz
« Reply #14 on: May 15, 2022, 07:34:21 pm »
I just leave this here for later  8)
Vintage audio gear connoisseur, computer enthusiast, time-nut, music lover, vintage games gamer, nerd, tinkerer and shady electronic projects maker.
http://www.martenelectric.cz/
  • Country: cn
« Reply #15 on: May 17, 2022, 05:53:58 am »
Q: Why did digital designers come late to work?
A: Insufficient margin in the bus timing.
« Last Edit: May 17, 2022, 05:57:54 am by niconiconi »
The following users thanked this post: Zeyneb, m98, MK14
Offline MuhScopeBroke
« Reply #16 on: May 17, 2022, 07:07:58 pm »
This may be the largest compilation of electronics jokes on this Earth, bless you
Offline Kaziq
« Reply #17 on: May 18, 2022, 09:21:12 am »
Q: Why AM radio receiver persuaded its brother to change his gender?
A: It wanted to have a trans-sister.
Also not exactly electronics, but anyway:
Q: What did Elon Musk name a company that didn't do anything interesting?
A: The boring company.
The following users thanked this post: MK14, MrMobodies, Ole
Offline MK14
« Reply #18 on: May 18, 2022, 09:50:21 am »
Q: How much charge, is there between a metal plated air-gap capacitor, with 1mm spacing and 2.5 volts across it ?
A: None, air is free of charge (£/$'s)
Q: Who can charge a fully broken/expired battery ?
A: A Businessman or taxman.  They can charge (£/$'s) for almost anything.
Q: Why does a capacitor, always give out electric shocks, even when fully discharged ?
A: Because capacitors, are usually not free of charge (£/$'s)
  • Country: cn
« Reply #19 on: May 18, 2022, 03:06:05 pm »
Q: How does an RF designer find the input impedance of an amplifier?
A: By taking a moment of reflection.
Online NiHaoMike
    • Facebook Page
« Reply #20 on: May 19, 2022, 02:04:12 am »
Whoever named the data bus obviously doesn't actually take the bus because those work like Token Ring!
« Reply #21 on: May 19, 2022, 08:16:00 pm »
what do you call two engineers that get along , but not with anyone else ?
the twisted pair
Offline MK14
« Reply #22 on: May 19, 2022, 08:27:46 pm »
Q: What component, is made up of crushed up, peoples pets/animals?
A: Cat5 Cable
Q: What type of weather, has the biggest storage capacity?
A: Cloud storage
Q: Which component, never gets caught by the Police?
A: A capacitor, as it always manages to out foil the police detectives
Q: Which component, appears most often in the Movies?
A: A film capacitor
Offline MrMobodies
« Reply #23 on: May 20, 2022, 03:38:53 am »
Q: What can cause buffer overflow problems at the tap?
A: Beer.
Offline bsfeechannel
« Reply #24 on: May 21, 2022, 12:04:45 am »
Why is a raven like a writing desk?
Neither knows how to solder.
