Author Topic: bad laptop design  (Read 1245 times)
Offline grifftechTopic starter
    • youtube channel
bad laptop design
« on: February 16, 2018, 04:25:51 pm »
The issue is that the trackpad does not work while any of the alpha-numeric keys are pressed. DELL LATITUDE 3340, win7 pro
Offline rrinker
Re: bad laptop design
« Reply #1 on: February 16, 2018, 05:13:08 pm »
 Do you mean, hold down a key and the trackpad no longer moves the pointer? My HP does the exact same thing. I'm pretty sure this is common across most systems. I can hold down a key and use my mouse and the cursor moves, though.
Offline AndyC_772
« Reply #2 on: February 16, 2018, 05:25:44 pm »
Sounds deliberate; many laptops have a setting which intentionally disables the track pad while the keyboard is in use, to avoid inadvertently moving the cursor and clicking on things while you're typing.
Have a look in the control panel to see if there's a Synaptics touch pad driver or similar. You can probably set it to work however you like.
Offline German_EE
« Reply #3 on: February 16, 2018, 06:45:34 pm »
This is intentional and I have it enabled on my Thinkpad as well. Imagine if you are typing away, pass your wrist over the trackpad and highlight some text, then hit another letter, you will lose the highlighted text.
Warren Buffett
Offline theleakydiode
  • I've got no idea what I'm doing.
« Reply #4 on: February 16, 2018, 08:28:43 pm »
Look in touch pad settings for "disable keyboard whilst typing". Yours will likely have similar settings buried somewhere.
« Last Edit: February 16, 2018, 08:31:18 pm by theleakydiode »
