what are some well know resistor brands. some that have good data sheet,etc. first class and second class resistors. I'm thinking of doing a science project( i'm fourteen) on the temperature variance of resistors.
Hello Peter,
for your project (i.e. about the 'Temperature Coefficient'), you don't have to select by manufacturer, but by technology.
Different manufacturers offer the same technologies.
The difference between manufacturers might be, how well they produce the components, i.e. that's about quality and reliability (not relevant for you), and sometimes, if they really fulfill their published specifications.
For your purpose, you'll need resistors of the main different technologies: Thick Film, Thin Film (= Metal Film), Carbon (hard to find), Wirewound Power, Wirewound Precision (expensive), Metal Foil (very expensive).
Provided you have a sophisticated DMM / Ohmmeter (4 terminal / Kelvin connection and maybe offest compensation), you may determine the T.C. of all of them (difficult for the high grade resistors).
Regarding manufacturers, VISHAY has acquired most of the high quality resistor brands as Beyschlag, Draloric, Dale, Roederstein, Sprague, etc.
Vishay also have their own manufacturing, and invented the metal foil technology.
Other independant and good suppliers are KOA, ROHM, Yageo, Panasonic.
Depending on your test setup, you'll need perhaps through-hole components instead of SMD.
Perhaps, you also want to include resistor technolgies for temperature measurements, i.e. with much higher T.C. and/or non-linear R(T) characteristics, then add NTC, PTC, Pt100.
(You'll need a thermometer, anyhow)
Frank
