Designed to power off the entire bench by disconnecting a relais. User the toner transfer method for the first time... not bad but a lot of work. I will use in the future sticker paper.
I like it.
What you guys have as "safety" on your bench beside brain?
PS: I was shocked to discover that Solidworks has not a mirrored Text option... at least in sketch. I had to do the text with pussy power point.
