Home charging has little future , in the uk the typical house limit is 60kw , and hence a 32 amp circuit is the max feasible limit. ( in fact for 32A you’ll need priority switching in some cases ) in fact many installers will only fit 16a EVSE in many cases.
I assume you mean 60A, to which I say, "bollocks!" I have never lived in a home with less than 100A service. 60A homes do exist, but most of them are supplied with 80A cabling and DNOs will install 80A fuses FOR FREE, if the customer requests so. That gives you an 18kW supply. DNOs will let you have two EV chargers on 80A if you pass diversity, usually one 32A and one 16A, but sometimes you can have two limited to 20-24A if they support it.
Most of continental Europe has at least 3x16A service (~11kW) and 3x32A (~22kW) is also quite common. The 3ph 16A people might need to limit themselves to 3.6kW single phase charging. That's still plenty fast for most.
Modern EVs currently have 60 kWh and trending towards 100 kWh batteries. , recharging 60kwh , on a 32A circuit takes 8 hours ( including taper charging ) , recharging 100kWh will be practically impossible in the typical night time available ( usually 12 -6am )
Hence home charging will be a fill-in activity
Remember the average mileage per week in the uk is very low. Most users drive short distances each day. With 60-100kWh batteries these users might only charge once a fortnight. These are most likely to take place at very high energy delivery sites.
These statements are contradictory. Most EVs won't need to charge up much or at all on a given night because their batteries are big and their mileages are low. And yet you think that we'll need to use rapid chargers for all EVs? The reality is, EV charging will mostly happen at home, or parked on the street using slow AC chargers. 3.6kW is enough for 80% of the population every night, 7.2kW would be enough for 95% (my estimation). Some EVs support more, Audi e-tron supports 40A single phase, and early Model S in Europe could charge at 63A single phase too, but I believe they have dropped that because the demand is so low.
Furthermore various grid studies show the primary concern of grid managers vis a vie EV charging is high density home charging at coordinated times like night time. The typically suburban estate ( with driveways ) has an electrical infrastructure simply incapable of supporting high density coordinated charging. The cost and sheer inconvenience makes it virtually impossible to upgrade this houses.
The typical suburban estate actually has sufficient capacity to supply 23kW to every home, it's the downstream DNO capacity where there are shortages.
The uptake of EVs will be over 10-15 years so DNOs will have sufficient time to upgrade. No doubt it will be a lot of work but heat pumps are another driver of this type of demand.
On top of that smart metering will in time penalise home charging of EVs , both by increasing the cost of the time of charge where co-ordinated charging is happening , ie night time. Smart meters are largely grid/ generator promoted as they want to monetised inelastic electricity usage times.
Well even on normal rates my (PH)EV is still much cheaper than petrol to run, about 5-6p/mile compared to 15p/mile.
Regarding cheap rates at night. Some say they will go, others not so sure. Personally I think as renewable energy becomes more common they will stay but the pricing will vary. Some nights no benefit others the price will plunge.
Right now there's roughly a 50% difference between daytime usage and nighttime usage. If everyone switched over to EVs and average mileages didn't change, then overall electrical energy usage would go up by about 20%. There would still be a night time gap.
The major advantage of a smart grid with EVs is it's dispatchable. If there's excess demand you tell all the EVs to soak up now and drop the rates to incentivise this usage. When there's a demand shortfall you reduce or stop charging altogether. Customers can override, but they'll pay a bit more. Some places in the US have a scheme where you can have your air-con scaled back in times of peak demand, this is exactly the same. And in the end, as long as your car has enough range for your next journey for the day, do you really care when it charges?
