Author Topic: Would this be tcp or udp networking ?  (Read 2007 times)
Offline ptricks
« on: February 04, 2013, 09:58:28 am »
Trying to determine how to implement this RFC for communication , would this be tcp or udp ?
http://www.faqs.org/rfcs/rfc2549.html
Offline PeterG
Re: Would this be tcp or udp networking ?
« Reply #1 on: February 04, 2013, 10:01:38 am »
It is IP based so it will be TCP most likely.
Been a while since i have seen such a document tho.......... entertaining..... :D
Regards
« Last Edit: February 04, 2013, 10:06:47 am by PeterG »
Testing one two three...
Offline GeoffS
« Reply #2 on: February 04, 2013, 10:05:27 am »
There no mechanism to compensate for missing pigeons so it's definitely UDP.
Offline AlfBaz
« Reply #3 on: February 04, 2013, 10:07:56 am »
I to agree that its UDP, given the rather large TTL time the reciever may be obsolete by the time the packet arrives
Offline PeterG
« Reply #4 on: February 04, 2013, 10:11:50 am »
Yes true, but how would you compensate for pigeons of different speeds. (If one stops to feed for example)? There would need to be a mechanism to re-sequence the out of sync datagrams.
Regards
Offline amyk
« Reply #5 on: February 04, 2013, 10:17:05 am »
It's on IP, and the IP layer doesn't guarantee delivery.
TCP and UDP are above IP, so theoretically they could both be used through it.
Offline baljemmett
« Reply #6 on: February 04, 2013, 03:22:32 pm »
Yes, this -- although the one practical implementation I've seen documented was only used to carry ICMP.  UDP would be obviously doable, TCP might be painfully slow though!
« Reply #7 on: February 04, 2013, 03:51:18 pm »
Has large latency, so Skype would be terrible through it.
Offline randyhenke
« Reply #8 on: February 04, 2013, 04:50:42 pm »
Would hate to see the aftermath of a DDOS from a carrier like that.
« Reply #9 on: February 04, 2013, 06:02:47 pm »
I saw a packet loss from it this afternoon, the local kite came in and took out the packet in front of me. He called it dinner for the wife and kids.
