[EDIT] My mistake, I think these references are individual BITs on the BYTE which is PORTA. It just looked confusing at first glance, until I put it into context by reading further down the code.
Thanks
Hello guys. it's me again, Mr confused. I don't understand the memory location references made under the heading "INPUTS". It is using memlocs that point to registers such as PCL and STATUS. I must be mis-understanding something here... or are these numbers being assigned just numeric values, and not actual reglocs?
list p=16f627
#include p16f627.inc
;THE LINES ABOVE JUST TELL THE COMPILER THAT WE'RE USING PIC16F627
__CONFIG _BODEN_ON & _CP_OFF & DATA_CP_OFF & _PWRTE_ON & _WDT_OFF & _LVP_OFF & _MCLRE_ON & _INTRC_OSC_NOCLKOUT
;VARIABLE DEFS
;INPUTS
SW1 EQU 00H ;SW1 TRIGGERS RA0
SW2 EQU 01H ;SW2 TRIGGERS RA1
SW3 EQU 02H ;SW3 TRIGGERS RA2
SW4 EQU 03H ;SW4 TRIGGERS RA3
;TIMERS (USED FOR DELAY_ROUTINE)
TIMER1 EQU 20H
TIMER2 EQU 21H
;PATTERN
PATTERN EQU 22H
;SET VECTOR TO 0
ORG 0
GOTO RESET
;DELAY ROUTINE - NESTED LOOPS
DELAY_ROUTINE MOVLW D'100'
MOVWF TIMER2
DEL_LOOP1 MOVLW D'100'
MOVWF TIMER1
DEL_LOOP2 BTFSC PORTA,SW1
GOTO MENU
BTFSC PORTA,SW1
GOTO MENU
BTFSC PORTA,SW3
GOTO MENU
BTFSC PORTA,SW4
GOTO MENU
DECFSZ TIMER1,F ;DECREMENT F, SKIP IF ZERO, STORE RESULT IN F REGISTER
GOTO DEL_LOOP2
DECFSZ TIMER2,F
GOTO DEL_LOOP1
RETLW 0
;MAIN INIT ROUTINE - SETUP PIC OPTIONS ETC
RESET MOVLW B'00000111'
MOVWF CMCON
BSF STATUS,RP0 ;SWITCH TO BANK 1
MOVLW B'11010111' ;SET PIC OPTIONS
MOVWF OPTION_REG ;WRITE PIC OPTIONS REGISTER
CLRF INTCON ;DISBABLE ALL INTERRUPTS
;SET INPUTS AND OUTPUTS
;PORTB
MOVLW B'11000000'
MOVWF TRISB
;PORTA
MOVLW B'11111111'
MOVWF TRISB
;SWITCH BACK TO BANK 0
BCF STATUS,RP0
;CLEAR ALL PORTB OUTPUTS
CLRF PORTB
;DEFAULT TO EFFECT_4 ON BOOT
GOTO EFFECT_4
