Hey Guys!
I was wondering if anyone had some good ideas on how to detect if a water pump is dead heading? I was considering using a pressure based switch, however the problem with that is I cannot find a decently priced differential pressure sensor designed for water use. I've looked at the MPX2010 line of sensors (well, the similar ones which handle higher pressure than the MPX2010) and using them with an air gap like those normal tank sensors but they specifically specify that they are designed for "dry air"... I was considering using this as a backup switch? The fact it mentions dry air makes me nervous - for just normal old water level sensing it's no dramas if it fails, but if this fails it will probably take our bore pump with it!!!
My other option was a flow based switch (which is preferable, in my mind), however I don't know the LPM rating of our bore pump which is a bit of a problem. I've heard the Doppler water flow sensors are quite good in that respect, is this correct?
A temperature based sensor would probably work, perhaps based on the fantastic DS18B20, however this will be going into drinking water. Perhaps one of those stainless steel waterproof versions? Basically the theory is that as the impellor is spinning it will heat up the water... But that's not foolproof!
Basically, over this summer our fantastic old Davey pump went belly up (On the weekend, mind you)! So we had to do some emergency plumbing and connect the house up to the bore pump for water. However, that pump has no pressure switch, so we had to keep turning it on and off in order to not dead head the pump.
Now I want to make a sensor for it which will cut the power if it detects dead heading.
Thanks, and I look forward to hearing from the lovely EEVBlog community!
Brendan
