Author Topic: Accumulator/battery and weight (charged vs depleted)  (Read 1339 times)
Offline evavaTopic starter
  • Country: cz
« on: October 24, 2019, 11:31:27 am »
I wonder if here on the forum is some physicist, who can calculate weight of the battery/accumulator which is depleted vs fully charged.
Is it significant amount of weight, or not any at all?
Energy delivered to the battery/accumulator should appear somewhere?
E=mc2
« Last Edit: October 24, 2019, 11:34:57 am by evava »
Offline amyk
Re: Accumulator/battery and weight (charged vs depleted)
« Reply #1 on: October 24, 2019, 12:01:55 pm »
Not significant but the energy does contribute a really really tiny amount of mass.
  • Country: cz
« Reply #2 on: October 24, 2019, 12:05:13 pm »
How much tiny?
Tesla car battery 80kWh, how much it weights fully charged vs depleted?
Offline Gyro
« Reply #3 on: October 24, 2019, 03:50:13 pm »
Far too small to measure.  ;)
« Last Edit: October 24, 2019, 03:51:57 pm by Gyro »
Best Regards, Chris
Offline Kleinstein
« Reply #4 on: October 24, 2019, 04:27:45 pm »
The formula is already give: a rough calculation in the head give something around 1 ng for the large battery.
Online IanB
« Reply #5 on: October 24, 2019, 04:57:43 pm »
How much tiny?
Yes, it's an interesting question. But you already posted the answer: E = mc²
E = 80 kWh = 3e+8 J
c = 3e+8 m/s
m = E / c² = 3e+8 / (3e+8)² = 3e-9 kg = 3 µg
That's more than I might have thought, actually.
The following users thanked this post: I wanted a rude username
Offline bdunham7
« Reply #6 on: October 24, 2019, 05:48:56 pm »
That'a not how it works.
Actually that is exactly how it works.  Although the binding energies and enthalpy change in chemical reactions or ion intercalation are much less than in a typical nuclear fission or fusion, the idea is the same--energy is released or absorbed depending on the relative energies of the before and after states and the mass of the system changes in proportion to that energy change.
The following users thanked this post: NiHaoMike
Offline tooki
« Reply #7 on: October 24, 2019, 06:11:30 pm »
E=mc2
Just a little FYI, since you made a point of adding the term “accumulator”: in English, that word does not mean “rechargeable battery”. (It does, in quite archaic usage, refer to lead acid rechargeable batteries, but only lead acid, and again, it’s obsolete English.) I know that many European languages use “accumulator” to mean any rechargeable battery, but English does not.
The following users thanked this post: evava
Offline mzzj
« Reply #8 on: October 24, 2019, 06:41:56 pm »
How much tiny?
E = 80 kWh = 3e+8 J
c = 3e+8 m/s
540kg battery and 3ug. That is almost measurable, ie Mettler HK1000MC mass comparator has 1kg capacity and 0.1ug resolution.
Scaled to tesla battery size that would be 54ug resolution
Offline shakalnokturn
« Reply #9 on: October 24, 2019, 07:48:09 pm »
Looking at energy densities taking only that delta into account shows how much room is left for improvement in battery solutions  :-\
The following users thanked this post: MagicSmoker
Offline thm_w
  • Non-expert
« Reply #10 on: October 24, 2019, 10:49:08 pm »
https://physics.stackexchange.com/questions/34421/does-the-mass-of-a-battery-change-when-charged-discharged
https://www.physicsforums.com/threads/weight-difference-between-a-charge-and-discharged-battery.703057/page-2
https://www.reddit.com/r/askscience/comments/1hj8k7/do_discharged_batteries_weigh_less_than_fully/
The answers here are assuming a perfectly sealed ideal battery but that is usually not the case. From the third link it looks like you have to go deeper, and consider the chemical effects as well, some will lose some will gain.
  • Country: cz
« Reply #11 on: October 25, 2019, 11:41:09 am »
Thank you all for answers!
Interesting subject.
