Author Topic: Running HDMI signal over ethernet twisted pair  (Read 866 times)
Offline AxkTopic starter
  • Country: by
« on: January 28, 2022, 05:44:37 pm »
There are these cheap RJ45 -> HDMI, HDMI -> RJ45 adapters on Aliexpress like this one - https://www.aliexpress.com/item/1005001577157733.html
Looks like they are just connecting the HDMI pairs to the twisted pairs without any smarts in them (I guess just impedance matching) - there's a teardown photo in one of the comments in the feedback.
Is there a standard for this type of thing or is it just kind of works but is not standardized?
I cannot find a standard for this, there's ethernet over HDMI, more complex adapters which actually convert it to ethernet packets, but nothing for these dumb passive connectors.
Offline thm_w
  • Non-expert
Re: Running HDMI signal over ethernet twisted pair
« Reply #1 on: January 29, 2022, 01:21:03 am »
Attached the photos you are talking about.
I don't think there would ever be a standard for something like this, as its not HDMI compliant.
The following users thanked this post: Axk
Offline NiHaoMike
    • Facebook Page
« Reply #2 on: January 29, 2022, 01:27:36 am »
A proper HDMI over CAT6 adapter has chips to boost the signal.
Offline Algoma
« Reply #3 on: January 29, 2022, 02:50:53 am »
Such passive adapters could operate over short distances at best, Even HDMI seems to need active cables for any remarkable length (30ft+)
Any signal integrity problems would cause HDMI to renegotiate its data rate, causing intermittent video issues. Longest (active) HDMI cable I've used was was 50ft active cable to a rear classroom camera as AUX input for a Conference system.
