Ok wow, so if I put anything decently thick in there, it trips the 15 amp breaker on my power bard pretty darn quickly, I was using an one of those aluminum pie pans, and decided to see how it performed on that.
Let's just say that with my auto darkening glasses and a smaller tip, I would easily be able to cut out custom heat shields and the like. It absolutely demolishes it, you don't even feel the pan, it just blasts through it. I need to find my tripod and take a video lol
edit: no clue where my tripod is, so just took a video, and damn the thing got piping hot pretty fast, I figured it would be cool as a cucumber, but I guess I'm pulling a pretty good amount of amperage out of it.
The aluminum was built up on the screwdriver tip, and when I tried to remove the ring terminal after cleaning most off, the metal just pulled clean out of the handle, I guess it warmed it up just enough.
Then, trying to put it back in, I jabbed a hole through the desk, apparently it's pretty thin material.
At least it's somewhat of a disposable desk. I'll post the video here when it's done, I don't think I'll be hammering the transformer this hard again, unless I bathe it in oil.
